09-17-2019
18:51
12:50
09-17-2019
18:51
12:50
Update in 2019 now dashboard app has irritating “tip” takes half screen every view I can’t see how to turn off! I saw 2018 solution for iconic but doesn’t work for charge2. Spam at it’s worse! I’ve even stopped updating stats it’s so bad. Any ideas/ solutions? Thx
09-17-2019 20:24
09-17-2019 20:24
There should be a X by the message. Use that to shut it down
Wendy | CA | Moto G6 Android
09-17-2019 21:23
09-17-2019 21:23
That merely deletes the pop up. Next time you sync.. it’s back. A new tip! Each and every time you enter the app another pop up. Yes you can x each time but i don’t want pop ups... didn’t ask for it.. not helpful.. should be optional. It’s a new ointerface push and to me is spam. Can it be turned off???
09-21-2019 19:57
09-21-2019 19:57
03-04-2020 19:23
03-04-2020 19:23
Hi there,
I have a question about these tips/msg popping out every now and then actually...I was reading rather useful article the other day following this "pop up msg" but as I was half way through my phone decided to die..
Is there any way to go back/find that one specific article and if so how do I get to do it??
Thanks in advance 😉
