09-30-2023 05:07
09-30-2023 05:07
As of this morning dashboard shows calories instead of steps. Why was this changed?
09-30-2023 14:14
09-30-2023 14:14
Did you change it? You can change it back by pressing the edit button on your dashboard and dragging the steps to where the calories are now I believe. Try it.
Best Answer10-01-2023 14:24
10-01-2023 14:24
Does it show just calories only or also steps. Check if your Fitbit is still paired.
Best Answer10-01-2023 15:48
10-01-2023 15:48
