07-27-2017 16:36 - last edited on 09-09-2020 09:26 by MatthewFitbit
For the past month my charge 2 has been quadrupling, at the minimum, the number of floors I climb each day. I have restarted the unit several times hoping that this would help resolve the problem, no such luck. On Monday of this week it had me at 236 floors in one day, every day this week it has been at over 100 a day. Usually, I'm in the 20 to 40 range and consider my stair climbing to be a valuable part of my activity. It's at the point now that I can't trust any thing it records with regard to flights climbed. I'm also concerned that all these extra added flights scew my step count as well. Any suggestions of how to fix this problem would be appreciated.
10-29-2018 14:07
10-29-2018 14:07
03-15-2019 18:53
03-15-2019 18:53
My charge two was logging way too many floors. It seemed to happen after I did an update. I tried all the suggestions on this site. Finally....I deleted the app and went to the App Store and downloaded it again. WORKED!!!!!
03-15-2019 18:57
03-15-2019 18:57
03-15-2019 19:46
03-15-2019 19:46
03-15-2019 21:02
03-15-2019 21:02
Yes. It even kept my data from earlier that day.
03-16-2019 14:05
03-16-2019 14:05
03-16-2019 16:42
03-16-2019 16:42
Thank you! I uninstalled and reinstalled the app! It works!
03-17-2019 05:39
03-17-2019 05:39
How do I uninstall my app and install it again
03-17-2019 13:58 - edited 03-19-2019 13:14
This is why I like that the inspire, it does not have an altimeter.
03-17-2019 17:16
03-17-2019 17:16
I have an iPhone. Press and hold on the app until it’s starts shaking and a little X will be in the corner. Press the x and it will say that it will delete all the info. Press ok. Then go to App Store and and go to fitbit app and reinstall. Hope this helps. Worked for me. Also after it reinstalls if you want to have it on the same place on your phone, hold down until it shakes and move it wherever you want. Message me again if you need too. 🙂
04-25-2019 15:23
04-25-2019 15:23
This solution does not work for the new Charge 2 I bought this week. I’ve reset it at least a dozen times and set it up as new device multiple times and it still days I’ve gone 63 flights when I’ve only climes one set today
04-25-2019 17:11
04-25-2019 17:11
04-26-2019 16:50
04-26-2019 16:50
Did you try to completely delete the app on your phone or tablet. Then go to App Store and re-install it? That worked for me.
05-31-2019 04:38
05-31-2019 04:38
my fitbit charge 2 floor calculating wrong... how to solve this issue..
08-04-2019 13:25
08-04-2019 13:25
I restarted then set it up as a new device. It worked correctly again for a couple of days and then started counting floors too high. I live in a one level house and it is showing 60 floors today.
08-04-2019 14:18
08-04-2019 14:18
08-04-2019 14:21
08-04-2019 14:21
Delete your app and go to the App Store and re-install was the app. Worked for me
08-04-2019 15:12
08-04-2019 15:12
i have charge 2 last evening went off i put in charge and after one hour went on again the tine is off to two hour i don.t know what to do.
08-05-2019 13:48
08-05-2019 13:48
08-05-2019 16:02
08-05-2019 16:02
