01-06-2020 09:41 - last edited on 09-08-2020 11:28 by
I have a Charge 2 and noticed the other day after taking it off of charge that is was stuck on Jan 4th with zero steps at 12:49. I have tried everything that I can think of to get it unstuck. I went so far as to unpair it from my phone and it will attempt to repair but because the screen won't change I can't pair it to my phone again, however my 6:45am alarm will go off. The button does nothing to the stuck screen. I have also attempted to reset it however the step that says keep the button pushed while taking it off the charger is impossible to do while keeping the button pushed in. So that also has not worked.
It is keeping track of my steps or at least it was until I unpaired it trying to fix it. Any and all help would be welcome.
01-07-2020
08:57
09:15
01-07-2020
08:57
09:15
@Jessie9r A warm welcome to our Community!
Let me help you with your Charge 2 screen being stuck and thank you for troubleshooting this issue. Let's retry the restart but remember that you don't need to remove the tracker. Plug it to the charging cable and the charging cable should be plugged to a power source (wall adapter or computer) as if you were charging it. Now press the button on the tracker for 12 seconds and see if it restarts (no need to unplug it during this step).
Let me know how it goes.
01-07-2020 13:25
01-07-2020 13:25
01-08-2020 09:18
01-08-2020 09:18
I had the exact same thing happen right before the holidays. I updated my app (iOS 13.3, iPhone 11) and updated the firmware, which took several tries and a long time. After that, all that appeared was a horizontal white line on the screen and my Charge 2 no longer synced with my phone. Per instructions on another site, I let it die and tried to restart again, but it didn't work. I don't know what else to do!
01-08-2020 10:00
01-08-2020 10:00
