04-23-2018 07:00 - last edited on 09-08-2020 18:54 by MatthewFitbit
My charge 2 quit syncing a few days ago. I've tried everything they suggested to get it syncing again with no luck. So I unpaired it and tried pairing it again with my phone. It won't pair. Any help would be much appreciated!
08-07-2018 08:05
08-07-2018 08:05
08-07-2018 18:09
08-07-2018 18:09
I had to restart my Fitbit several times before I could pair up again. The last time I did it I turned off bluetooth on my phone, restarted my phone and then restarted my Fitbit before I paired it to my phone. It stopped pairing again after several hours so I restarted my Fitbit which worked. I also have it paired with my Amazon Fire which I was keeping close to my phone. After separating the two so bluetooth on both were far apart I have not had any pairing problems.
04-10-2019 00:49
04-10-2019 00:49
Allthough it has been a year since this was marked 'resolved' I also - and still - have this problem. My setup is Iphone 5SE OS11.4 latest download of Fitbit app, with Charge2.
It fails to connect. This started after a sync had been attemped while de Bluetooth on the iPhone was turned off. After turning BT on, it just fails. And keeps failing to connect.
And yes I got it working after all mantioned steps. Only to have it fail again the next day... Now I have run through the steps two times to no avail.
So. is the the only real option here: running through all mentioned steps many times? The disconnecting and 'forgetting' of the device. Turning off and on of the phone, re-installing the app, connecting to charger and then rebooting it at least three times as long as 12 seconds?
Let me guess, I know the answer: new phone, new fitbit. Stuff only works perfectly for a maximum of 24 months... We do work on our fitness, not the stamina and long life of machines...
04-10-2019 06:57
04-10-2019 06:57
04-10-2019 10:00
04-10-2019 10:00
