12-18-2019
05:03
10:32
12-18-2019
05:03
10:32
The band on my Charge3 randomly becomes disconnected from the bottom portion of the tracker several times a day. You can see on the actual device that the clips on the tracker are not as prominent on the bottom as they are on the top. I had a Charge3 develop these problems about 10 months after I started using it, contacted FitBit and got a replacement sent. The replacement has the same exact issue. The bands are from FitBit and only have this problem when attached to the bottom of the tracker, not the top. Is this a known defect? Is there a different version that does not have this same issue that I can look into?
12-18-2019 09:33
12-18-2019 09:33
My charge3 band is broken at the attachment and I have been unable to find replacement wristband on site. Anyone know if they are available?
Best Answer12-18-2019 17:30
12-18-2019 17:30
This happens if dirt gets stuck in the connectors I used cocktail sticks to remove it. May take a while but It should reconnect.
03-26-2020 06:36
03-26-2020 06:36
I followed the instructions for replacing the band on my charger 3 and I am experiencing the same problem, the one side of the band that contains the holes does not click in place. There is no debris, it just does not click in place. This is quite frustrating, as the Fitbit itself is fine. Please note also, that my band just suddenly broke without warning. What do I do to make the band click in place?
03-26-2020 09:56
03-26-2020 09:56
I had that issue only the spring action actually stopped working so I had to pry the connection bar up prior to connecting my band. I decided to just by a new one and save the other for a backup.
so frustrating.
Best Answer03-08-2021 06:49
03-08-2021 06:49
Did you buy a new band, or a new watch?
Best Answer03-08-2021 06:50
03-08-2021 06:50
What did you end up doing to resolve this? I have tried a new band and it also does not stay connected, so I assume that it’s something wrong on the watch itself.
Best Answer03-08-2021 06:53
03-08-2021 06:53
My partner cleaned the connection using cocktail sticks and then I ordered a new band from amazon. I haven't had a problem since fingers crossed.
Best Answer03-08-2021 07:03
03-08-2021 07:03
Best Answer03-08-2021 12:02
03-08-2021 12:02
@LoLoMcVickers It's nice to have you on board!
Let me help you with this and thank you for cleaning the device. This does seems odd but you can try the great suggestion @Letters2u307 shared with you about using a toothpick to clean the area. I really don't want you to spend more in a new device if this can be saved by something like this. If you are still having issues then I suggest you contact our Support team for further assistance. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Hope this helps.
10-26-2021 13:33
10-26-2021 13:33
Having the same issue. Fitbit works but band won’t stay attached. I’ll try toothpicks
10-26-2021 14:40
10-26-2021 14:40
Best Answer11-19-2021 13:45
11-19-2021 13:45
I am having the same problem with my Charge 4
Best Answer11-20-2021 02:45
11-20-2021 02:45
My Fitbit did the same thing. I called Fitbit support. Mine was still under warranty and they had to send me a new Fitbit. No band, just the device itself. I was lucky still under warranty.
13:12
09:29
11-20-2021
13:12
09:29
Thanks for getting back to us @miasunnysideup and welcome @lesliemc_99. Thank you for sharing your wristband inquiry.
I'm glad to hear that you got a new Fitbit @miasunnysideup.
@lesliemc_99, confirm that you have followed the steps of How do I change the band on my Fitbit device?
Keep on visiting the forums.
Best Answer01-01-2022 13:12
01-01-2022 13:12
I am having same problem with bottom section. Did you get any band to stay?
Thank you
01-01-2022 13:22
01-01-2022 13:22
I called fitbit and they replace the watch part. Mine was still under warranty. A pice of the part the connects was loose/bent and wouldn’t stay connected. I bought new bands too for the replacement
01-01-2022 13:40
01-01-2022 13:40
Best Answer01-01-2022 14:01
01-01-2022 14:01
Best Answer01-01-2022 18:40
01-01-2022 18:40
I bought brand new vans from Amazon. Got three in a package and two of them immediately break off of the clock face once I put them on my wrist
