Charger 2 not uploading to PC using Toggle.
ANSWERED
Charger 2 not uploading to PC/Fitbit database using supplied wireless Toggle(?). It worked before. Now updates only using Fitbit App on cellphone.
1 BEST ANSWER
Accepted Solutions
Hi @Grog77  Fitbit removed the ability to sync or set up via computer and a dongle quite some time ago. Everything now must be done with our smartphones.
Stepping in the U.S.A. since September 2013. Android 14
2 REPLIES 2
Thank you for your reply.
It was "some time ago" that I did notice the change but did not research the reason. Again thank you for the reply.
