07-27-2021
17:05
04:04
WilsonFitbit
07-27-2021
17:05
04:04
WilsonFitbit
22 month old Charger 3 with v. Reliable history. Then this happened:
Screen impossible to read except in v. Low ambient light. HR monitor not working despite clock face changes and rebooting. What's wrong?
07-28-2021
04:10
10:30
07-28-2021
04:10
10:30
Hello @Hempton. Welcome to the community forums.
Thank you for the detailed information and for the troubleshooting steps you've tried prior to posting. At this time, I'd like to let you know that I'm not sure about what exactly could have caused this matter, but I'd recommend performing a long restart to your Charge 3 by following the instructions below:
For the screen that is dim, please make sure that it is set to the correct brightness setting and that your Charge 3 hasn't gone into sleep mode. When the sleep mode setting is on:
To change this, press and hold the button, and swipe left to access the quick settings screen. Tap a setting to turn it on or off. When you turn off the setting, the icon appears dim with a line through it. For more information, see How do I navigate my Fitbit device?
Lastly, please make sure your Charge 3 is running the latest firmware version. If you notice it has a pending firmware update, please update it by following the instructions here. Also, make sure the Fitbit App is up to date.
Hope this helps.
07-28-2021
04:10
10:30
07-28-2021
04:10
10:30
Hope this helps.
08-04-2021 21:34
08-04-2021 21:34
08-05-2021
04:38
10:31
08-05-2021
04:38
10:31
@Hempton Thank you very much for your reply.
I'm glad to hear that the long restart seems to have resolved the inconvenience. I hope you can continue tracking towards your fitness goals.
See you around.
08-07-2021 22:16
08-07-2021 22:16
Unfortunately the fix was short lived.
The HR monitor has again ceased to work (there's no green light showing at the back of my fit bit.)
I even tried a factory reset but that reset didn't seem to "happen"
Fitbit sent me a 30% discount code for a limited range of fitbit styles. Do they know that my fitbit is on the way out?
Thanks for any help you can offer
Hempton
08-08-2021 17:25
08-08-2021 17:25
08-09-2021 04:34 - edited 08-09-2021 04:36
@Hempton Thank you for your replies.
I'm sorry to hear that the inconvenience persisted and I appreciate your help in trying to resolve this matter. I was able to see that you were able to reach out to our Support Team and the provided a 35% discount.
Regarding your question, I'd like to let you know that since they exhausted all the troubleshooting steps and the issue persisted, they confirmed that the Charge 3 was deem defective, therefore, they reviewed your warranty options but they noticed that your Charge 3 is no longer under warranty. For more information about our warranty policy, I recommend visiting the following link: https://www.fitbit.com/global/us/legal/returns-and-warranty.
See you around.
08-14-2021 13:40
08-14-2021 13:40
08-19-2021 06:06
08-19-2021 06:06
I appreciate the detailed information and thanks for being part of the Fitbit family and for considering a new Fitbit device. I hope you can continue tracking towards your fitness goals.
See you around.
