03-17-2019
06:58
16:45
03-17-2019
06:58
16:45
Hey!
Quick question re edercise tracking and calories burned. If you choose the running option on your device and set off for your workout but end up walking for a good 65% of the time, will the calories burned still be calculated on the assumption that you are running, or will they be calculated based on distance and pace? In other words, if I did the same exact workout but had chosen the ‘walk’ program instead, would i have the same calorie burn?
thanks!
03-19-2019 06:02
03-19-2019 06:02
@iwillthinkof I am almost 100% sure that it doesn't make a difference. Your Charge 2 uses heart rate based algorithms for calculating calorie burn. Also, I took a recent Walk and changed it to a Run. The calorie burn didn't change.
One thing I don't have an answer for is if this "mostly walked" run tracked as a Run messes with your Cardio Fitness Score. There are threads from other users that talk about Cardio Fitness score dropping for no good reason. I recommend Walk until you are really running most of the time. Something to think about.
Laurie | Maryland
