12-22-2018
04:39
06:54
AlejandraFitbit
12-22-2018
04:39
06:54
AlejandraFitbit
Since the firmware update a few days ago my Charge 3 no longer displays my steps on top or heart rate below on the clock face, this is despite steps being set as my main goal. Instead it displays the lightening symbol and is constantly showing 0. What do I need to do to restore it back to original setup.
12-26-2018 11:32
12-26-2018 11:32
I think I'm having the same problem and here's why: Fitbit changed the available clock faces with the latest update. I loved having the steps, time, and HR displayed. It seems that clock face has been changed with the update, so that the information at the top of the display cycles through as you tap the screen. If you tap the display, it will switch from the lightning symbol to steps to calories, etc... It's a terrible setup. I just want to glance down and see my steps at the top, but now even accidently hitting my wrist, I change what's displayed (in your case, it's the lightning symbol now). I really hope Fitbit changes it back. 😞
12-23-2018 06:55
12-23-2018 06:55
Welcome to the Forums @DanCantRun.
Have you tried to restart your tracker? If you haven't, I recommend restating it by doing the following:
Let me know how it goes.
12-26-2018 11:32
12-26-2018 11:32
12-27-2018 05:39
12-27-2018 05:39
Yes I believe your right, an unfortunate design choice by the Fitbit team
04-11-2020
07:57
06:18
AlvaroFitbit
04-11-2020
07:57
06:18
AlvaroFitbit
I have tried to reset my charge 3, but nothing seems to change the clock face, or the brightness. It is
very faded out on the right side. For instance at 10:15 the 10 will appear, but can not see the 15. Also when I get a text , the print is very faint, not readable.
Would like to be able to wear it, but unusable at this point. Any suggestions?
Moderator Edit: Formatting
07-23-2020 12:24
07-23-2020 12:24
Perhaps it is because of the impending upgrade, but I do not have any place in the fitbit app that shows clock faces. No where. Help?
klkaa
11-12-2020 09:52
11-12-2020 09:52
This response did not change anything on my Fitbit.
Anyone else have something to attempt that lit the clock face up on their Charge 3?
thanks for any help.
11-15-2020
07:10
08:02
11-15-2020
07:10
08:02
@DanCantRun I hope you're doing well!
Let me help you with your Charge 3 not working and thank you for troubleshooting this issue. Since the issue persists I have created a ticket so our Support team can further assist you via email.
