Completely confused setting up my Charge 3
Brand new, just FINALLY trying to set up my Charge 3 (gifted to me a year and a half ago!) but the set up instructions do not seem clear.
The fit bit is Hard wired to my Win 10 machine, but as far as I can tell, my Win10 is not seeing the Charge 3.   There is an option to purchase the Bluetooth dongle, which I might at some point, but the instruction simply don't tell me how to set this thing up and what to look for.
I would love to hear back from someone
Thanks in advance.
1 REPLY 1
There are some set-up instructions here.
As far as I know, the cable is only for charging and won't actually connect the Charge 3 to your PC. For that you need bluetooth.
There's some information about syncing here. That page also links to a blog entry that deals with checking whether your PC has bluetooth or not. If it does not, your best bet to get it working is buying the Fitbit dongle.
Good luck
