09-26-2017
17:42
09:26
09-26-2017
17:42
09:26
My Charge 2 battery completely died and now it will not charge and has zero signs of life. Not lights on the back and nothing in the display. I've had it plugged in for 24 hours now and tried resetting it but still get nothing. I know the outlet works because I charge my phone there all the time and I've tried different cubes to make sure. It's not even a year old yet so I hope it's not broken for good. Anyone else experience this?
09-26-2017 21:09
09-26-2017 21:09
I have on earlier models but not on this one. In previous instances this was solved by holding the button down for up to 20 seconds and it should become alive....
@Kmitchell256 wrote:My Charge 2 battery completely died and now it will not charge and has zero signs of life. Not lights on the back and nothing in the display. I've had it plugged in for 24 hours now and tried resetting it but still get nothing. I know the outlet works because I charge my phone there all the time and I've tried different cubes to make sure. It's not even a year old yet so I hope it's not broken for good. Anyone else experience this?
09-26-2017 22:11
09-26-2017 22:11
Same thing happened to my FitBit Charge 2 this week. One suggestion was to dab alcohol on the charging pins and now not even the green lights come on. I tried resetting per instructions . Completely dead. Not even a year old. Not able to resurrect this thing.
09-27-2017 08:47 - edited 09-27-2017 08:48
@Mongaby wrote:Same thing happened to my FitBit Charge 2 this week. One suggestion was to dab alcohol on the charging pins and now not even the green lights come on. I tried resetting per instructions . Completely dead. Not even a year old. Not able to resurrect this thing.
If my tracker goes completely dead, it sometimes takes 8-12 hours on the chatger before any life shows, and another 2-3 before charged. Then i need to do a restart.
10-12-2019 17:06
10-12-2019 17:06
Yes mine has done the same thing, it worked perfectly this morning went to bed and it's dead, not even a year old and I have the fitbit ionic.
Best Answer10-12-2019 18:26
10-12-2019 18:26
I'm having the same problem. Mine still shows small signs of life though. I charge it. It says it's full. I put it on. And it's dead. But the green lights are on. They're barely on. But they're there. My charge 2 is about 18 months old. I've tried restarting it. Idk what else to do.
10-12-2019 19:48
10-12-2019 19:48
10-12-2019 22:36
10-12-2019 22:36
Best Answer10-12-2019 22:46
10-12-2019 22:46
Best Answer10-13-2019 08:58
10-13-2019 08:58
Best Answer10-13-2019 09:41
10-13-2019 09:41
Best Answer10-13-2019 09:54
10-13-2019 09:54
More like 8 months old
Best Answer10-13-2019 09:59
10-13-2019 09:59
I've tried that got my green light back for 10 secs.. But screen still won't come one, tried about twice I gave up now, back in the box. Were it will stay, I just keeping using my blaze I've had that for 3 years with no problems at all.
Best Answer10-13-2019 10:09
10-13-2019 10:09
Best Answer11-15-2019 13:49
11-15-2019 13:49
After 2 years 2 months my third Fitbit died. This is my last Fitbit ever! I could buy a 50 dollar watch and it would last me a life time. I will never recommend your product.
11-15-2019 14:21 - edited 11-15-2019 14:23
Your battery in the watch will not last a lifetime.
I agree a good mechanical watch will last a lifetime. An electronic one will not.
I have my grandfather's over 100 years old pocket watch.
11-15-2019 15:20
11-15-2019 15:20
So send us a battery with instructions so we can use it again.
02-11-2023 08:37
02-11-2023 08:37
Mine did the same thing today. It was turning intself on and off a couple times yesterday, today it is dead. This is literally the 3rd fitbit I have had to buy. Seems they last just over a year (conveniently just out of warranty) and then bite it. Since it seems this product has a short lifespan I am going to look for something less expensive this time. Probably won't go back to fitbit until they can build it with a replaceable battery because I hate this kind of waste.
