03-11-2019 12:03 - last edited on 12-23-2020 15:38 by LiliyaFitbit
Does anyone attend Hotworx
I want to connect watch to sych
03-11-2019 12:48
03-11-2019 12:48
Welcome to the forums!
I do not see t on the app list Here:
So you might want to check on their site if it can be linked
Hope to see you around!
Wendy | CA | Moto G6 Android
07-31-2019 11:49
07-31-2019 11:49
Were you able to connect your fitbit to Hotworx?
12-28-2019 09:56
12-28-2019 09:56
I have been trying to get my Fitbit and Hot Worx app to sync for weeks without any luck. I’m not sure where to find any answers? The Hot Worx app video on You Tube isn’t any help and I don’t see anything on the Hot Worx app for either help or syncing options.
02-01-2020
15:17
06:16
JuanJoFitbit
02-01-2020
15:17
06:16
JuanJoFitbit
Same 😒
Uuggh
No
Moderator edit: merged reply
02-22-2020 14:48
02-22-2020 14:48
I can connect but I get readings like 43 calories burned for yoga and I know it has to be more than that
02-22-2020 22:37
02-22-2020 22:37
Please check with Hot Worx
02-23-2020 07:17
02-23-2020 07:17
03-04-2020 10:46
03-04-2020 10:46
Me too! It even gave me "-" calories for the afterburn. Were you able to figure out why? I have an older Fitbit, the Flex. I am wondering if this is the problem.
06-16-2020 13:08
06-16-2020 13:08
Has this been figured out yet? It says I burned 42 calories.
06-16-2020 13:10
06-16-2020 13:10
06-17-2020 06:01
06-17-2020 06:01
06-17-2020 06:15
06-17-2020 06:15
06-17-2020 06:35
06-17-2020 06:35
I upgraded my fitbit to a Charge 3 (from a flex) and the calorie output was still pretty inconsistent. Sometimes I would burn 15 calories and others I would burn 175 calories for the same workout.
1. I now make sure my fitbit is synced before working out. I open the fitbit app and sync, before opening the hotworx app and starting the session.
2.The fitbit has to be tight on your arm. I noticed it reads better if the band is tightened.
It now seems to be reading the calories more accurately.
Since I have done these 2 things consistently, my calorie burn has been reading accurately.
06-18-2020 12:27
06-18-2020 12:27
I will try tightening and syncing, thank you! How many calories does it say? Also, does it record active minutes?
06-18-2020 16:23
06-18-2020 16:23
You have to "Start Session" through the Hotworx App. And that session has a time set, so a class is automatically set up to record for 45 minutes and the HITT sessions record for 15 minutes. Then a 1 hour afterburn is recorded after your class is complete and you press the button to start the afterburn. You then will be promoted to record your afterburn calories when completed.
I used to burn between 250-350 calories depending on what class I did. The app now says I burn between 150-175 per class. I think that there is some type of glitch somewhere. It might be because of the type of device I am using. Idk. A friend of mine has noticed the same decrease with her calorie burn. We both use fitbits. I talked to an apple watch user and they have not noticed any differences, they are still burning around 250 per session. Hotworx says it is not a problem on their end.
Not sure what is going on. But something is different. I hope this helps.
09-21-2020
20:15
07:11
JuanJoFitbit
09-21-2020
20:15
07:11
JuanJoFitbit
Same no credit for all of my sweating on the Hotworx app via my versa! Help please.
I have the same problem no credit for my Hotworx Burn via my versa!
09-22-2020 08:27
09-22-2020 08:27
11-01-2020 17:38
11-01-2020 17:38
Did you find a solution to this I'm having this same problem?
11-01-2020 18:28
11-01-2020 18:28
