05-11-2020
09:29
09:40
05-11-2020
09:29
09:40
Hello,
After switching from my old Samsung A5 to S10e I have noticed that the connected GPS data is now almost all wrong. Instead of a nice curve, I have a crazy jumping line with a lot of gaps in GPS reception. Also, I do not see any system notification - it was something like "Connected GPS is running" in the system tray fo the A5 in the past.
I guess it is somehow related to Samsung's power policy, however, after turning it off completely as suggested at https://dontkillmyapp.com/samsung I still have the same weird GPS results.
Any more recommendations, please?
BR
Pavel
05-24-2020
10:04
05:06
05-24-2020
10:04
05:06
@pgrishkov I hope you're doing well! Sorry for the delay in my reply.
Let me help you with your Connected GPS not working properly on your new Samsung S10e phone and thank you for check the battery saving options. So this feature did work on your previous phone correctly, right? I suggest you try refreshing the link between your phone and your tracker by doing the following:
Let me know how it goes.
