12-10-2023 14:51
12-10-2023 14:51
Hi,
I have a fitbit charge 4 but I’m thinking about buying another fitbit. But I’ve heard that I cannot connect more devices to one account using a gallery. So I’m wondering if I can connect my fitbit charge 4 to one of the devices who isn’t using the gallery option?
Or doesn’t it work it at all for the fitbit charge 4?
12-10-2023 18:02
12-10-2023 18:02
@Sonea_ , A warm welcome to the Community Thank you for your message.
If you try to add another Charge 4 to the 1 Fitbit account, you'll be asked if you want to replace the original one from the account. You can only have 1 Fitbit device of the same mode paired to your account at a time.
I;m not quite understanding your question, could you elaborate it?
If you are referring to the clock face gallery, only the Charge 4 paired with the account will be using the clock face.
12-11-2023 05:16
12-11-2023 05:16
@Sonea_ I'm also trying to understand your question. It sounds like you own a Charge 4 and you want to add a Fitbit that doesn't have a Gallery. It sounds like you want to switch easily between two Fitbits, without having to remove one to add the other. Fitbit put the Gallery on its devices in 2018 or so. All current Fitbits have a Gallery. Models that don't have a Gallery are very old and out of date.
Laurie | Maryland
12-11-2023 07:45
12-11-2023 07:45
Sorry if i wasn't clear enough, English isn't my first language.
But yes, i want to have 2 devices on one account but I was wondering if i can combine anything other than another charge to to my account. Like my current charge 4 with maybe a Sense or something else.
