05-08-2017
15:46
20:15
05-08-2017
15:46
20:15
I went from Dallas (Central time zone) to Newark (Eastern time zone) this weekend for a conference. The fitbit reset its time/time zone when I landed in Newark just fine. However, when I returned to Dallas two days later, it would not reset, even though my phone went immediately back to Central time. I researched the forum, then I resynched several times. I then spent more time searching the forums, then "reset" the device. Still showing Eastern time. Finally, I spent more time searching and discovered that there's a time zone setting in the "Advanced Settings" feature under "account". I turned off from automatic and manually reset the time zone to Central and it worked. I still have no idea why it didn't reset initially or why the resynching / reset didn't correct the problem. You guys really need to put the time zone function some place a bit more obvious.
05-10-2017 13:29
05-10-2017 13:29
Hey @CarlaKDallas, it's awesome to see you here. I want to thank you for the feedback provided about the timezone settings location in our platform, this is really important since we're always looking forward to improve our services and products. I'm glad to know that you were able to resolve this issue by yourself, if at any point this happens again I suggest these steps.
Hope to see you around more often. ![]()
What's for breakfast?Check others recipes and share yours!
Best Answer05-10-2017 13:54 - edited 05-10-2017 13:58
I also have the same problem. I traveled to Pacific time and my fitbit did not sync with Pacific time the entire time I was there. However, when I came back to Mountain time, my charge hr switched to Pacific time without me doing anything. I also reset it in the 'advanced' settings, but my fitbit is still on Pacific time.
Best Answer05-11-2017 17:25
05-11-2017 17:25
Hello my friend @melfi92, it's nice to see you here.![]()
Well, this is really odd, this should not be happening, my recommendation is following the steps I posted in the following threads:
Hope this helps and let me know if you have more questions. ![]()
Best Answer03-09-2020 16:54
03-09-2020 16:54
Thanks I had the same problem.
