04-29-2018
10:28
18:54
04-29-2018
10:28
18:54
My charge 2 has suddenly developed a crack on the face. It was not there one night and next morning appeared. I am 72 and do not do anything that would have caused it. It runs along the right side about an eight of an in inch in. I would like a replacement as this is something I use everyday.
04-30-2018 12:41
04-30-2018 12:41
Read the warranty first:
https://www.fitbit.com/legal/returns-and-warranty
Then contact support
http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Or you can call (877) 623-4997 between the hours of 4am-8pm PST Mon-Fri and 6am-5pm PST on weekends
Wendy | CA | Moto G6 Android
Best Answer05-01-2018 12:02
05-01-2018 12:02
Hi there @Lamplady, welcome to the Fitbit Community Forums! 🙂
I'm sorry to hear you're having problems with your Charge 2 but I've just checked with our Support Team and it seems they're already taking good care of you, so if you need anything else, feel free to let us know and keep an eye on your inbox for more instructions.
Good luck!
Best Answer05-01-2018 13:15
05-01-2018 13:15
Best Answer05-01-2018 13:52
05-01-2018 13:52
That has happened to me twice. Fitbit was great and replaced my first cracked screen. Now the new one has a crack in the same place. It is also identical to the crack in your picture. I doubt they will replace mine again so I may just live with it. They need to fix this quality issue. Otherwise, I have loved my fitbits.
Best Answer05-01-2018 14:27
05-01-2018 14:27
Mine did exactly the same. Honestly It was hit or knocked so I can't understand why.
Best Answer05-01-2018 17:27
05-01-2018 17:27
Best Answer02-11-2019 02:56
02-11-2019 02:56
Me to duds find another brand
Best Answer07-04-2020 05:23
07-04-2020 05:23
Mine started to crack just after one year, just out of warranty. Since then it had got worse and now the display is partially unreadable and also dim!!
I think the bin is calling, but a replacement Fitbit??
