10-21-2019
05:23
10:40
10-21-2019
05:23
10:40
Do do cycle a lot and have started to track my distance using my Charge 3. Frustratingly the distance cycled does not show on the dashboard and doesn't seem to count toward the total km of the daily activity log.I am sure this is a well known issue but is there any way to add the distance cycle to the daily activity dashboard? We are currently running a sports competition at work where the total distance walked, ran or cycled counts towards the overall fundraising goal.
10-21-2019 09:29
10-21-2019 09:29
Hello @VD1220 are you manually starting your bike tracking and using the connected GPS on your phone? This is the only way Fitbit will know the distance that was ridden.
As for bike distance. This does not get added to the days distance since this was not stepping.
Best Answer10-25-2019 04:51
10-25-2019 04:51
Thanks Rich!
yes I am starting my exercise activity manually on my Fitbit and use my iPhone for the GPS tracking.
I still find it very difficult to understand why Fitbid has decided not to add road cycled distances to the daily exercise distance. Its clear that I have exercised from the pulse rate readings. If there has to be an associated step count the app could allow to define an average cadence and bike tire size which would be sufficient to translate the cycled distance back to 'steps'. I find it really frustrating as I am cycling a lot and none of that appears in the dashboard and is subsequently handed over to other apps such as MoveSpring which we use at work for exercise competitions.
10-25-2019 08:43
10-25-2019 08:43
Best Answer01-27-2020 18:33
01-27-2020 18:33
Is there a way to go back to the old behaviour, where Fitbit tracks "activity" instead of only steps.
Best Answer01-28-2020 14:31
01-28-2020 14:31
I'm not sure of the old way @sserf Fitbit has been using burned calories as the common factor between exercises.
