07-10-2022 15:32
07-10-2022 15:32
The screen have gone darker and darker through the past half year. First I just couldn’t see the time on it when outside, now I cant see anything on it at all. Not even inside a dark room or at night; so I’m no longer able to even put an alarm in or use any of the functions on it. It is still sending data to my phone though.
It is charged, the light is not dimmed, it is updated/reset and I never had it in water (even though I think it should even be able to?).
What can I do?
07-11-2022 18:47
07-11-2022 18:47
Welcome to the Fitbit Community, @Juliavp.
Thanks for trying to resolve the display issue you’ve had with your Fitbit Charge 3 before getting in touch with us.
In addition to the regular restart, you can perform a long restart:
You can also try to change the clock face of your Tracker:
Hope this helps.
Best Answer07-13-2022 16:17
07-13-2022 16:17
Hi Edson,
thank you for your reply.
I have tried out both your suggestions without luck. A bit tricky when not able to see anything on the Fitbit screen, but at least it does still respond with the vibrations.
Is there anything else I can try or somewhere to find help for this issue?
Julia
Best Answer07-13-2022 18:41
07-13-2022 18:41
Thanks for the update, @Juliavp.
The best way to get help for this problem is to chat with us online or give us a call. Please click here to get connected.
Have a nice day.
