Device not recording active minutes
I teach 2 fitness classes every Saturday morning... Body Pump and Indoor cycling.  Today my Fitbit Charge 2 did not record any active minutes and I KNOW I should have at least 90... usually more.  It has also not been syncing all day... recently.  I have to manually sync.  What's up?
4 REPLIES 4
Hi @OIBeachYogini, welcome to the Community Forums! Sorry for the delayed reply.
Thanks for bringing this to my attention and the details that were shared in your post. To better assist you with this, can you please let me know which mobile device are you using to sync your Charge 2? When was the first time you experienced this issue and how many times since then? In the meantime I receive your answers, please restart your device and then learn more about how active minutes are tracked here
In regards the syncing issue, please try the steps that are outlined on our help article: Why won't my Fitbit device sync?
Looking forward to your reply.
I'm using an android Galaxy 8 phone... and this is the first time I've worn
my device and had it NOT track activity. Unfortunately, over the past few
months, it has not done "all day sync" so I'm afraid something may be going
bad in the device... All Day Sync is turned on in the app and bluetooth is
on... but it won't sync.. I have to manually sync.
LIFE is GOOD!!!
Your prompt reply is appreciated @OIBeachYogini.
I appreciate the details that were shared with me. How are you tracking your exercise? Are you using the exercise shortcuts or the SmartTrack auto-recognition feature? Which activities were not recorded? The All Day sync feature can be compromised if you're not using a compatible device with our products and services, please check on our list of compatible devices if you're using one. If such is the case, please test your Charge 2 with a compatible device instead and let me know if the issue persists.
Keep me posted, I'll be around.
I use SmartTrack auto-recognition and it's been working fine for years... I
taught a Body Pump class and then an Indoor Cycling class... neither class
was recognized. No active minutes recorded on Saturday.
Now, on Sunday, I went for a long run and used the Interval tracker and
everything was good.
You know what... also, the Fitibit frequently won't recognize my heratrate,
like right now. I just looked at it and beside the ❤️ is just -- two
lines. This if often the case. Can you advise??
Is it wearing out?? I would love to keep it....
LIFE is GOOD!!!
