09-21-2019
05:42
12:50
09-21-2019
05:42
12:50
All of a sudden my Fitbit stopped recording heart rate and sleep, but it will still record steps, hourly exercise stats and sync. It also will only keep a charge for one day! What is wrong and how can I fix it?
Moderator edit; Subject for clarity
09-22-2019
18:26
09:28
09-22-2019
18:26
09:28
Hi @Southporty, welcome to the Community Forums!
I appreciate the information that was shared in your post. Let me share with you that the battery of our Charge 2 device was designed to last 5 days but this also depends on how frequently you use it’s features. That said, I recommend you charging your Fitbit device with a USB port from a computer or a UL-certified outlet into the wall and then turn off all the features that you don’t use that much. After doing so, please this help article for more tips and recommendations.
Regarding the sleep inconvenience, can you please let me know if your device is recording sleep information but not Sleep Stages? Also, when was the first time you experienced this and how many times since then? Take in consideration that if you're experiencing heart rate difficulties, your device will not track Sleep Stages. Please expand on this sleep information concern so I can better assist you.
Regarding heart rate tracker, can you please let me know if the heart rate sensors of your device are still flashing? I recommend you to check our help article: Why don't I see my heart rate on my Fitbit device?.
Keep me posted and let me know if you have any additional questions.
Best Answer09-23-2019 05:30
09-23-2019 05:30
Thankyou for your reply. My Fitbit exhibited these problems starting on Sept. 8, and ever since then. I do charge my Fitbit either in an approved USB port or with a wall adapter. I did restart my Fitbit according to directions here. The charge lasts about a day now compared to before when I could get nearly a week. The restart seems to have improved the life to slightly more than a day when prior to restart, it wouldn’t last a whole day.
The heart recording function: does not flash, displays the last resting heart rate.
I have read other posts which seem to indicate a glitch with the newest update.
I would appreciate additional help. I have made sure all of the other advice given in your reply has been followed.
thank you
21:29
08:42
09-27-2019
21:29
08:42
You're welcome, thanks for your reply and update @Southporty. Sorry for the delay in responding your post.
Thank you for bringing this to my attention, the details that were shared with me are appreciated. I was informed by our Support team that they already provided you assistance regarding this situation, therefore, my best advice for you will be to contact them back if you have any additional questions about the information that they provided to you.
I'll be around if you need anything else too.
