01-21-2022
11:03
16:48
EdsonFitbit
01-21-2022
11:03
16:48
EdsonFitbit
1- The tracking will stop working when the GPS signal is lost temporarily instead of exprapolating, which Charge 3 used to do and other brands do. I can no longer use safely Charge 3 for biking or mountain biking rides with a group (instructor)
2- The screen has progressively become dark. I cannot use it anymore 2 years later. The lifetime is seriously short. Obsolescence should be better managed, unless this is a voluntary and unresponsible act to push us to buy the next generation.
Moderator edit: added label
01-24-2022 16:47 - edited 01-24-2022 16:51
Thank you for visiting the Fitbit Community, @Wuist.
I'm sorry to hear about the difficulties you experienced with your Fitbit Charge 3. Thank you for the information provided.
In this case, I would recommend restarting your Tracker by following these instructions.
If you haven't done so, please try to change the brightness settings to see if there is any improvement. In addition, please make sure Sleep Mode and Do Not Disturb (DND) are turned off. For instructions on how to navigate your Fitbit device, please visit this article.
You can also change your Fitbit device's clock face by following these steps.
Hope this helps.
