06-06-2017
16:51
09:49
06-06-2017
16:51
09:49
After about 2 months my display dimmed and now I can bare lee it, I was told it can't be adjusted and can't be returned. I can only view my stats through my phone, am I the only one?
06-07-2017 00:04
06-07-2017 00:04
I would get back to customer support. If you are still within warranty (it runs for 12 months from purchase) and it has a defect, customer support should offer a replacement.
Best Answer06-07-2017 00:04
06-07-2017 00:04
Best Answer06-07-2017 07:53
06-07-2017 07:53
Thanks I contacted customer service again and this time they are sending me out a replacement charge 2, the first person felt I wanted a refund not a replacement.
06-07-2017 07:58
06-07-2017 07:58
@SunsetRunner I hope you're doing well! The first thing to try is restarting your tracker (do this 3 times in a row) by doing the following:
Plug the charging cable to your computer or UL certified wall adapter.
Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely.
Your tracker should start charging.
Press the button for 10 to 12 seconds.
You should see your tracker's firmware version and you can now unplug your tracker.
If your tracker doesn't work after this then you will need to contact support like @SteveH suggested.
Let me know how it goes!
Best Answer03-17-2020 16:30
03-17-2020 16:30
I have 2 questions, some may find stupid.
What does it mean/ needs to be fixed when this occurs? And if it's now been 2.5 years, am i out of luck?
