09-16-2017
16:00
09:26
09-16-2017
16:00
09:26
When i take ny arm up, the clock will not show. Just when i press the button . Is it possible to turn something on to get it on?
Sorry for my bad English writing 😂
09-16-2017
16:16
06:27
AlvaroFitbit
09-16-2017
16:16
06:27
AlvaroFitbit
@Cecilie000, in the app Device Settings ensure that Quick View is enabled. Make sure to sync your tracker after making any changes to the settings in the app.
07-05-2018 14:47
07-05-2018 14:47
this doesn't apply to the versa? I don't see the quick view option anywhere in any kind of settings.
Best Answer09-04-2018 08:01
09-04-2018 08:01
I had the same problem. Try pressing and holding the left button so that the clock face changes to another screen, Music Controls. From that next screen you can either swipe left (or is it right?) to get to the setting "Screen Wake", where you can set it to Auto. Hope that helps.
01-06-2019 22:23
01-06-2019 22:23
This worked for me on my iconic. Thanks.
01-14-2019 08:45
01-14-2019 08:45
For some reason my Ionic's quick v
iew or "Screen Wake" defaulted to manual. Thanks for the advice. Curious, what is the lower right-side button for?
Best Answer01-14-2019 10:09
01-14-2019 10:09
Best Answer01-23-2019 05:00
01-23-2019 05:00
I have the same problem actually and I can’t find that Quick View in my Charge 3 settings. Would you help me?
Best Answer01-23-2019 08:04
01-23-2019 08:04
Best Answer02-28-2019 05:41
02-28-2019 05:41
Thanks for the info, I was struggling with the same issue and your suggestion worked great!
Best Answer03-11-2019 05:18
03-11-2019 05:18
That worked. Thank you
Best Answer04-02-2019 12:28
04-02-2019 12:28
Many thanks!!
Best Answer05-30-2019 05:59
05-30-2019 05:59
Thank you!!! I was working out in my garden last night and I must have bumped the button and it changed the setting. I couldn’t figure out why it just stopped working.
Best Answer11-30-2019 17:13
11-30-2019 17:13
I had same issue, hold the button in on charge3 and touch Screen Wake
12-01-2019 09:56
12-01-2019 09:56
Best Answer12-15-2019 12:54
12-15-2019 12:54
That did the trick for me on my Charge 3. THANK YOU!
Best Answer01-13-2020 07:44
01-13-2020 07:44
Thanks. Brilliant.
Best Answer03-26-2020 15:40 - edited 03-26-2020 15:42
Excellent info -I have had this problem for the last two months and thought it was my watch that was broken!!! thanks!!!
03-27-2020 06:54
03-27-2020 06:54
Thanks for the tip! It worked.
Best Answer10-27-2020 10:28
10-27-2020 10:28
Thank You! My 5yr old was playing with it the other day so I figured it was a setting but couldn’t for the life of me find the page he had it on...
