Display not working on Charge 2
The display on my Charge 2 stopped working. I get nothing. It still syncs to my phone, but no display and no notifications. I have restarted multiple times, but no change. Anyone else experience this?
339 REPLIES 339
I'm having similar problems with my Charge 2 to others on this thread. Display is stuck at either 11:46 or 4:32, but the device seems to be tracking still-- my stats show up in the dashboard here. Resets, charging, changing the clock face, reinstall app on iPhone-- none worked.
Guessing I need a new tracker. The one thing I really have liked about the Fitbit over the past year is that the sleep sensor seems significantly more accurate than the Garmin devices that I tried. Does anyone here have a rec for a tracker that is good on sleep tracking?
No display on my Fitbit charge 2
Same thing happened to me. But because my warranty is only good for so long I basically got an email from Support that said “Sorry about that. Here’s 25% off your next Fitbit.”
I’m thinking, are these things designed to break after the warranty so you have to purchase another?! How does the screen just suddenly stop working? All I did was wake up and put it on my wrist, it’s not like I fell on the screen. Fitbit doesn’t care about solving this widespread problem.  SCAM!
mine has just gone blank after pixellating earlier. Mind it is 3yrs and 3 months old so its done well
My fitbit is 2 years old - worked fine till now - the display is now gone.  The phone works, vibrates and syncs.  Very recently, i unpaired the phone from my android and then realized that i cannot pair it again since i cannot view the 4 digit number.  is there any way to a) restart the display and b) pair the phone without the display
Mine stopped after they forced me to update the firmware and they are not bothered. They are just saying - we can't do anything please bin your device ...third class support ...useless good for nothing
I have tried the suggestion of holding the button fir 19 seconds but still no display
How long did it work?
A little over a year. It still syncs and records but I have to double tap it to see display and can’t see it at all in sun light. I really love my Fitbit, but will probably try another brand because of display issue when this one totally stops working.
Sent from my iPhone
This is my situation, too. I feel like the company just wants me to buy a new one to replace this one.
Yes. They do and there isn’t anything out there yet that is as good (until this breaks of course). Or unless you like huge smart watches (I don’t). For a tracker I like these best. But it seems strange they cannot make product that lasts.
Sent from my iPhone
they actually sent me a replacement, but that one won,t charge at all-- had
to call them again-- took over an hour to get a rep--told me i was still
using the old one and that's why it didn't charge!
Called back the next day-- another hour to get a rep-- sending a new
charging station this time--
I am not buying a new one-- this is my second anyway-- would go to another
brand if they can't get this right--
I’ve had 4. Tried a Samsung tracker and hated it.
Oh well. Fitbit should improve quality control.
Sent from my iPhone
I tried the reset, but it didn't work.  😪
Thank you. After pressing and hold the button for 10 to 12 second, it display the firmware number and the display is working
it doesnt display the software version. it doesnt display anything. I just tried it with mine. I have been having the same issue since last thursday evening. it will still track to my phone but no display.
I have tried the suggestions with regard to restarting a fully charged fitbit 2 in order to get the display to reset but still have been unsuccessful. Any other suggestions. It still works and is linked to my phone but I use it as a watch so, not having a display is very frustrating.
Yep! Still sinqs but display I have to double click to show, and you can’t see it at all in the sun light! I love the Fitbit but hoping for another brand like it for Xmas or bday because of screen.
Sent from my iPhone
I have done this and the display still does not turn on. What else can I do/try?
