02-27-2017
18:25
10:13
02-27-2017
18:25
10:13
The display on my Charge 2 stopped working. I get nothing. It still syncs to my phone, but no display and no notifications. I have restarted multiple times, but no change. Anyone else experience this?
07-08-2020 19:08
07-08-2020 19:08
thanks for the reply, Boothby!
My Charge 2 was holding a charge well, I only had to recharge it about every 4th day. It was still at 80% charged on Saturday morning, and sometime Saturday afternoon, the display went black. I tried to charge it, but it just got hot, still had no display, and the app on the phone could not "locate the tracker". I did get ahold of customer service after trying to restart the phone, but they just said it was out of warranty, and offered me 25% off of a new watch (certain models only). I'm disappointed to have to replace a watch that was seemingly working fine, and I'm skeptical to buy another fitbit as, like I said, this is my 4th in 5 years
07-09-2020 16:16
07-09-2020 16:16
restarted my fitbit charge 2 3 X's, no luck..
07-09-2020 23:07
07-09-2020 23:07
So did it start back, if so what did you do because I can’t get mine to come back up
15:08
09:03
DavideFitbit
07-10-2020
15:08
09:03
DavideFitbit
nope, restarted it 4 or 5 times without any luck...
unfortunately, it didn't do anything. It still tracks, but have to look at the app on either my phone to see information or my desktop...I am looking at a new tracker, not sure which direction to go...
07-10-2020 15:28
07-10-2020 15:28
I have now read 15 pages of reviews from frustrated charge 2 users dating from early 2018 all reporting the same problem with the watch display and the same lack of support from fitbit as soon as the warranty expires. Its official - the reboot "fix" worketh not. I now feel lucky mine lasted as long as it did (2 yrs) before giving up. My wife's lasted just over the year. The charge 2 was not cheap and not value for money. When i save up that much money again, i'll try a garmin or apple
07-10-2020
17:26
06:43
AlvaroFitbit
07-10-2020
17:26
06:43
AlvaroFitbit
Mine went dark and stayed dark
Moderator Edit: Personal info removed
07-10-2020 19:39
07-10-2020 19:39
And I now have an offer of 25% off, from Fitbit.
I appreciate the offer, except:
02:02
09:03
DavideFitbit
07-11-2020
02:02
09:03
DavideFitbit
Fitbit strap works fine for me.... unless you want to look at it to see ur
activity, check ur heart rate, tell the time, etc. Can use it to look at ur
reflexion in the right light🤔
Srry to hear that boothby 171... useless fitbit probably the least of ur
worries. Bettr luck with altrntives.
07-12-2020 07:48
07-12-2020 07:48
My display was showing upside down and a reverse mirror image with a line of short horizontal bars down one side of the screen. I thought my Charge 2 was dead and i would have to invest in a new device. I tried this solution following the instructions and after the third pressing of the button, my screen display was perfect! Thank you!
07-12-2020 08:29
07-12-2020 08:29
Loved my Fitbit Charge 2 until it stopped working Cleaned contacts, did the reset 3 times. Worked for half a day and now a blank screen. Will recharge again today. Other ideas?
Best Answer07-12-2020 11:59
07-12-2020 11:59
07-12-2020 14:14
07-12-2020 14:14
Best Answer07-12-2020 16:06
07-12-2020 16:06
Lauryn, I'm glad that worked for you. I've tried resetting it many, many times, with no luck.
I'm just going to let it sit and discharge for a week, and then charge it up and try again.
Best Answer07-13-2020 19:54
07-13-2020 19:54
07-14-2020 07:35
07-14-2020 07:35
After trying for many many times to fix this issue, I gave up and let the battery get depleted. Then all of a sudden, after a few days I pressed the button and it worked.
I should point out that in between I removed the tracker from the account even without seeing the screen.
I hope this helps someone.
Still, fitbit sucks with their response
07-15-2020 07:17
07-15-2020 07:17
Thanx xlomi....
Not sure i can wait on the chance the fitbit might wake up... but thanx - mayb i wont bin it yet.🤔
Best Answer07-15-2020 07:39
07-15-2020 07:39
I take it all back.
It lasted no more than 2 hrs. After about an hour it started flickering and having some strange lines appearing on the left, and than died again.
So Fitbit still sucks, and what a shame, being a pioneer in the market.
07-17-2020 18:41
07-17-2020 18:41
So after the same thing happening to me I decided to contact Fitbit support. They were incredibly unhelpful and provided no solution. There have been so many users with the same issue and they haven't done anything to fix it. After more research I found out that the Charge 2 is just a poor made watch as many people say it has not lasted them for more than a year. With that being said I am now a proud Apple watch owner and would highly recommend others to make the switch as well.
08-01-2020 11:44
08-01-2020 11:44
I tried your advice and my screen is still black its fully charged and syncing to my phone but still no display... Any help/ideas to try
Best Answer08-01-2020 12:32
08-01-2020 12:32
