02-27-2017
18:25
10:13
02-27-2017
18:25
10:13
The display on my Charge 2 stopped working. I get nothing. It still syncs to my phone, but no display and no notifications. I have restarted multiple times, but no change. Anyone else experience this?
07-25-2019 21:32
07-25-2019 21:32
I won't buy another one.
Best Answer07-29-2019 10:55
07-29-2019 10:55
good afternoon. went through all of your steps and still there is no display on my charge 2.
Best Answer08-28-2019 18:35
08-28-2019 18:35
Just past a year, and just after a firmware update from Fitbit, the bottom 2/3 of the screen faded away to nearly invisible. I contacted Fitbit by email. They responded two days later saying “sorry” and gave instructions to restart, etc. I had included in my email that I had gone to the community forum and had tried the restarting 3 times methods to no avail. They obviously didn’t read my whole email. This appears to be a consistent problem with Fitbit charge 2 and charge 3 as well (all over the Internet). I, my husband, and two friends all have had to replace multiple fitbits just out of warranty. First the strap breaks and Fitbit sends a new one (within warranty) then the device stops working in some way. I have had 4 fitbits. I like the product when it works. But as many here say, they don’t last at all. Too bad.
08-28-2019 22:49
08-28-2019 22:49
My charge 2 has a blank screen. I have tried the suggestions listed...VERY frustrated
Best Answer08-29-2019 02:42
08-29-2019 02:42
Best Answer09-13-2019 01:31
09-13-2019 01:31
My display not coming up since last 3 days what is the meaning of restart- when I press the side button ( when it is on the charger - connected to power) after a few seconds - there is a small vibration ..does that signify restart? If yes - I have done it 10 times. No use at all please help. The Fitbit is getting fully charged ( as I can see in the mobile app) and syncing perfect ; counting steps and stairs all fine. ; Only issue is no display.
09-13-2019 02:00
09-13-2019 02:00
09-13-2019 10:15
09-13-2019 10:15
Best Answer09-13-2019 18:38
09-13-2019 18:38
Best Answer09-13-2019 22:11
09-13-2019 22:11
Buy a different brand.
Best Answer09-16-2019 13:44
09-16-2019 13:44
Best Answer10-01-2019 05:42
10-01-2019 05:42
I have tried 3 times to reset and nothing yet. Anything else i can do?
Best Answer10-01-2019 06:29
10-01-2019 06:29
Best Answer10-01-2019 06:49
10-01-2019 06:49
Best Answer10-13-2019 08:45
10-13-2019 08:45
I just wanted to say thank you to AlvaroFitBit. I tried your suggestion and my display is working again. My Fitbit Charger 2 isn't even a year old. I went to bed with the display working and it had stopped showing anything by morning. Now it's working again.
Best Answer10-16-2019 20:12
10-16-2019 20:12
My charge 2 display wont come on... it is less then 2 years old... I tried the reset stuff as mentioned in this board... but of no avail. On contacting fitbit they say I am out of warranty and it cannot be fixed...
Not sure if I will spend my money on a tracker
Best Answer10-17-2019 05:47
10-17-2019 05:47
The display has stopped working on my Charge 2 too! It had a fine crack in the screen for a long time - but it has always worked well, and the crack was so fine it was not noticeable when it was displaying.
Then all of a sudden half the screen disappeared so I recharged it. After normal duration of charging I tried the screen and there was absolutely no display at all! It is still working though as I get reminders to charge it even though I have stopped wearing it.
Best Answer10-17-2019 05:58
10-17-2019 05:58
My Charge 2 display disappeared after setting watch on top of cable box for less than a minute. Has anyone else had issues with em radiation from other devices or heat? The box would be a little cooler than a 40W light bulb.
Best Answer10-19-2019 09:46
10-19-2019 09:46
Best Answer10-19-2019 18:05
10-19-2019 18:05
