02-27-2017 18:25 - last edited on 09-09-2020 10:13 by MatthewFitbit
The display on my Charge 2 stopped working. I get nothing. It still syncs to my phone, but no display and no notifications. I have restarted multiple times, but no change. Anyone else experience this?
04-15-2021 05:04
04-15-2021 05:04
No. Both i and my partner will not be willing to pay for an upgrade. This will be going to the Australian Dept of Fair Trading for this case - especially given so many people appear to be having the same problem simultaneously. I had a fair amount of conversation with Fitbit support who promised to get back to me in the next day or two. Four days later - nothing. Piss poor support
04-15-2021 05:17 - last edited on 06-22-2023 09:02 by DavideFitbit
I can’t say much (because when I do they private message me they they have removed my post because it’s irrelevant).
I’ll say this — I have purchased 4 fit bits and not a single one has lasted two years. That’s all. You do the math.
I also will not upgrade this time. I’ve owned 4 fitbits over time, and all failed right after the one year mark.
04-18-2021 03:11
04-18-2021 03:11
04-19-2021 04:58
04-19-2021 04:58
Mine stopped this morning, about 45 minutes ago. Screen is blank, no data, nothing. What's going on?. I've tried to contact FB via the app it won't connect, pushing me to Twitter instead and I do not have a Twitter account!
04-19-2021 05:17
04-19-2021 05:17
04-19-2021 16:28
04-19-2021 16:28
06-05-2021 22:44
06-05-2021 22:44
Didn’t work for me! Fitbit Charge 2 Display quit showing anything a few days ago but it still syncs with the app, charges and tracks everything! Worked when I went to bed; nothing showing the next morning!
06-11-2021 12:54
06-11-2021 12:54
I've tried a few of these solutions but nothing is working. I don't think I'll trade up to another fitbit since I see so many people with problems. I have lost some faith in the brand.
06-11-2021 13:12
06-11-2021 13:12
06-11-2021 14:14
06-11-2021 14:14
06-12-2021 02:37 - last edited on 06-23-2023 04:43 by LizzyFitbit
I’m going to see if Australian Consumer Authority can do anything
Moderator Edit: Personal info removed
06-12-2021 05:11
06-12-2021 05:11
07-21-2022 05:58
07-21-2022 05:58
No change: display still blank
07-21-2022 20:54
07-21-2022 20:54
After 2 fitbits with the displays dieing I switched to Amazfit GTS. I have been happy with it.
08-24-2022 05:50
08-24-2022 05:50
My dad's Fitbit Charge 2 got the same problem: the sensor is still working with green lights but the display is black. Somehow I could restart the display after a number of times trying. First I connect it to the charger, then press and hold the button until the display shows the Fitbit symbol (I also notice there is a white band on the side of the screen). I take it off the charger, then press the button again; sometimes nothing is showing so I repeat the process again until it does. I put it back on the charger, leave it there for a while then press the button again. If the battery symbol is showing, there is a chance that the display will work again. I leave it on the charger for a bit longer then take it off and try to press the button to see if anything is showing. I do not know how I got the display working again but I keep doing that until it does. The Fitbit Charge 2 manual does not show any troubleshooting at all which is so frustrating. Too bad I do not have anything to video record what I did to show.
08-26-2022 21:48
08-26-2022 21:48
After 3 different fitbits having the same problem, My wife and I changed to Amazfit brand from walmart. We have had them for 2 years without any issues.
08-26-2022 23:18 - last edited on 09-14-2022 21:39 by YojanaFitbit
Thanks for letting us know
Don’t blame you. Will never buy another Fitbit
Cheers from Oz!!
12-06-2022 23:05
12-06-2022 23:05
For anyone else having this issue please restart the tracker first 3 times in a row by doing the following: Plug the charging cable to your computer or UL certified wall adapter. Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely. Your tracker should start charging.
Regards,
Will
12-07-2022 16:57
12-07-2022 16:57
I'm having exactly the same problem. I'll throw it in the bin before I buy a new one. We should get more than 1 or 2 years out of it considering they are not cheap. Customer Service is rubbish.
06-22-2023 07:06
06-22-2023 07:06
Today I had a really funny situation with the firbit charge 2 display. I'm not talking about displaying everything from right to left or shifting the image a few pixels to the right or no display at all. Today I had a situation where the screen is always showing the same. Same time, same heart rate and steps. The funniest thing was that at 7:00 in the morning when I woke up I checked and it was 10:29. I thought I was late for work :). Nothing helps to improve the situation. Changing the display template or restarting the device did nothing. The funny thing is that the screen goes on and off as usual. It seems that the Fitbit Charge 2 screen is a separate device and may just freeze. I guess I will have nothing else to do than wait for Charge 2 to discharge. Interestingly, the first problems with the screen (no image) appeared just after it was fully discharged and put into the charger. When connected, the device vibrated but showed nothing. Of course, as others have written, all other functionality of the device is working.
