02-27-2017
18:25
10:13
02-27-2017
18:25
10:13
The display on my Charge 2 stopped working. I get nothing. It still syncs to my phone, but no display and no notifications. I have restarted multiple times, but no change. Anyone else experience this?
12-30-2018 20:49
12-30-2018 20:49
From the first time I contacted Fitbit about the failed unit, they were clearly following standard protocol of asking us to try certain resetting features, giving us a vague hope that somehow the device would be fixed.
While all along they know the end result is otherwise.
And this community is also not helping in any way. Fitbit is happy and would allow us to vent our feelings here, as long as we dont raise these concerns with proper consumer rights protection authorities.
Countless devices have failed with the same problem and the company isnt paying heed to it. They would listen only when their sale drops drastically by then it would be too late.
Best Answer12-31-2018 04:04
12-31-2018 04:04
Best Answer12-31-2018 08:34
12-31-2018 08:34
In general help desks have a script with troubleshooting steps that are known toto help with specific problems.
The steps to try generally will vary with the type of device being used to sync/setup through making it helpful to add when requesting help on these boards. I degrees.
I find that if the help desk is not able to help, I can get the help person to contact a technician or will ask to have the case esculated.
12-31-2018 13:10
12-31-2018 13:10
Best Answer01-02-2019 06:52
01-02-2019 06:52
Tried this, didn't change a thing.
Best Answer01-02-2019 06:54
01-02-2019 06:54
Tried what @Timkatt I don't see any quote to know who you're referencing
01-02-2019 10:50
01-02-2019 10:50
Hi Rich,
I don’t know who you are and how old are you? However, your working style is very amateur way. If you would like to guide the users, please make a video for reference. Everything should be clear and transparent.
Please do not talk general something & no-sense words if you would like to be the company’s representative here.
Best Answer01-03-2019 06:18
01-03-2019 06:18
I guess in addition to the screen on my fitbit, the reply feature of this message board doesn't work either.
Best Answer01-05-2019 16:12
01-05-2019 16:12
Display not working but still hooked up on phone
Best Answer01-05-2019 22:22
01-05-2019 22:22
Best Answer01-07-2019 13:14
01-07-2019 13:14
Fitbit is still sync to my phone but the display is not working how can I fix this?
Best Answer01-07-2019 16:08
01-07-2019 16:08
Very similar problem although there is a very faded display (I know this because I can see it when in a dark room); however under normal lighted conditions, I cannot see the display. The fading of the display was gradual over about three days.
Best Answer01-26-2019 04:59
01-26-2019 04:59
This worked! Thanks
Best Answer02-04-2019 23:15
02-04-2019 23:15
Best Answer02-06-2019 06:06
02-06-2019 06:06
I tried this solution once, and got a line to display, but nothing else. Tapping or resting did nothing. Tried it a second time and it worked.
Best Answer02-07-2019 01:47
02-07-2019 01:47
Hi
Same problem with my Charge 2 - green lights OK, syncs with phone, records data but screen is completely dead. I have followed advice re resets but this has not solved the problem. The Charge 2 buzzes when I reset but there is no display on the screen. Disappointed!
02-09-2019 16:19
02-09-2019 16:19
I opened the clock faces option and chose a different one and it worked. Then I chose the original one and it worked too. Problem solved.
Best Answer02-09-2019 18:29
02-09-2019 18:29
Best Answer02-09-2019 18:46
02-09-2019 18:46
I have tried the restart suggestion but it's still not working
Best Answer02-10-2019 05:45
02-10-2019 05:45
