11-30-2018
09:17
14:34
11-30-2018
09:17
14:34
I have just had to return my Charge 3 after only buying it on 3/11/18.
Display stopped working for no apparent reason. Store Tech said he had never seen it happen before. So replaced it. So not impressed.
03-16-2019 15:33
03-16-2019 15:33
03-17-2019 00:50
03-17-2019 00:50
My Charge 3 stopped last night after only owning for 2 months so I will change the clock face too. Thank you for the advice
Best Answer03-17-2019 16:43
03-17-2019 16:43
Best Answer03-18-2019 01:01
03-18-2019 01:01
Hello,
yes it did work so there is a problem after time using the analogue clock. Surely this needs to be sorted by Fitbit as have now read a lot of issues with the same issue? Thank you so much for the advice
Best Answer03-18-2019 04:18
03-18-2019 04:18
@HSW76 wrote:Hello,
I have had my display go out a couple times and do not use the analogue clock face. I have always been able to get the display back by either a reset or changing the clock face (and then changing it back). So, it may not be an issue on what clock face you are using.
Best Answer03-18-2019 06:53
03-18-2019 06:53
Second display drop. Second restoration with a forced restart.
Best Answer03-18-2019 13:58
03-18-2019 13:58
I had nothing to loose so I tried again, still had a white line, tried a third time and viola! Up and running again yay!
03-18-2019 14:27
03-18-2019 14:27
I guess persistence is the key!
Best Answer03-19-2019 20:14
03-19-2019 20:14
Mine quit working today when I tried to select an exercise as I was about to start my run. Could not get it to restart using the suggestion of plugging it in to charge and holding the button for 8 seconds. After reading about the clock face I tried that, and it worked. I hope it was just a small glitch and does not happen often.
Best Answer03-19-2019 20:34
03-19-2019 20:34
Best Answer03-21-2019 05:01
03-21-2019 05:01
I've had my Charge 3 for a month. My screen went blank last night. I tried the fix this morning and it worked! I'm so happy because I didn't want to have to return it.
03-21-2019 06:45
03-21-2019 06:45
Mine stopped scrolling down to let me look at data (steps, stairs, minutes exercised, etc.) and this worked for me except one thing was different. I had it connected to the charger correctly, and I never did get the battery icon (because I still had 50% battery?) but when I pressed and held the button for several seconds, it started working again.
03-22-2019 22:21
03-22-2019 22:21
Wasn’t working either but took your advice and it came right back with the smiley face. Thanks! I was hoping I wouldn’t have take my Fitbit back! 😊
03-23-2019 01:38
03-23-2019 01:38
Hi. My fitbit was working fine then suddenly the display stopped working. I tried the restart process - It doesn't work. I bought the device end of January/ beginning of February 2019.
Could someone help please?
03-24-2019 06:59
03-24-2019 06:59
It's happened two more times now, where it stopped scrolling down and I had to push the side button for several seconds. The second time, it came back like the first time. The third time, I fought with it for a while before it came back. If it keeps doing this, I'm returning it. For what the Charge 3 costs, I expect far better than what I've gotten so far.
Best Answer03-24-2019 08:01
03-24-2019 08:01
I so totally agree. These gadgets are not cheap. Fortunately mine has been behaving for a while now after a couple of weeks of frustration.
Best Answer03-24-2019 09:29
03-24-2019 09:29
Best Answer03-24-2019 09:43
03-24-2019 09:43
Best Answer03-24-2019 11:24
03-24-2019 11:24
This worked for mine the screen had been out for two weeks and it was sitting in the box but this fixed it! Thank you!
Best Answer03-24-2019 11:36
03-24-2019 11:36
