11-30-2018
09:17
14:34
11-30-2018
09:17
14:34
I have just had to return my Charge 3 after only buying it on 3/11/18.
Display stopped working for no apparent reason. Store Tech said he had never seen it happen before. So replaced it. So not impressed.
01-23-2019 18:10
01-23-2019 18:10
The problem is fixed! Thank you so much!😊
Best Answer01-30-2019 16:45
01-30-2019 16:45
Thank you so much! Changing the clock face worked when all other suggestions failed!!
Best Answer01-30-2019 17:36
01-30-2019 17:36
So glad it worked for you. Changing the clock face is now my go to solution for everything as resetting it never seems to work.
Best Answer01-31-2019 17:33
01-31-2019 17:33
Thanks for the restart procedure!! My Charge 3 display stopped today after I received it for Christmas from my son-in-law. The restart worked and my screen is working again!!
Best Answer02-07-2019 18:51
02-07-2019 18:51
What clock face did you change it to?. Mine is doing the same thing
Best Answer02-07-2019 20:00
02-07-2019 20:00
I didn't change the clock face, I had to restart it.
Best Answer02-08-2019 03:26
02-08-2019 03:26
I chose a random one. It doesn’t seem to matter which one you choose. I changed it right back to the one I like after. Worked every time. Caveat: I do a 15 second reset first then change the clock face. Hope this works for you!
Best Answer02-08-2019 04:58
02-08-2019 04:58
Best Answer02-08-2019 11:08
02-08-2019 11:08
Best Answer02-11-2019 03:06
02-11-2019 03:06
Worked for my waych! Thanks. I've been trying to find a solution for days. The restart did not work for me either. Probably a software glitch. Maybe they just need to update that watch face? It happened while using the Mod Clock interface . I'm wondering if the interface matters?
Best Answer02-11-2019 03:15
02-11-2019 03:15
Best Answer02-12-2019 05:12
02-12-2019 05:12
Hey,
This was quite helpful. However, I would appreciate if you could respond with the reason for this issue?
Regards and thank you for your time,
Vedang.
02-12-2019 06:28
02-12-2019 06:28
I’m sorry but I have no idea why. There must be a software glitch.
Best Answer02-12-2019 14:59
02-12-2019 14:59
Best Answer02-12-2019 15:06
02-12-2019 15:06
All I can say is Fitbit should never had released a new product without first making darn sure it was ready for the public. I had an Alta for two years and I never had an issue with it. Would have kept using it but I wanted more features and it was a Christmas present. WHEN the charge 3 works, it is great. The operative word is when.
Best Answer02-13-2019 16:40
02-13-2019 16:40
By changing the clock face setting my Fitbit started working again. Hope yours does too.
Best Answer02-18-2019 20:22
02-18-2019 20:22
Best Answer02-19-2019 04:51
02-19-2019 04:51
Best Answer02-19-2019 13:26
02-19-2019 13:26
you reset did not work, When I plugged it in there was no charge display on the fitbit. So What do I do next?
Best Answer02-19-2019 15:08
02-19-2019 15:08
I’d try it again. Sometime it’s taken me a couple of times to get it to work. If it doesn’t work then, I have no idea what to do. Sorry 😐
