11-30-2018
09:17
14:34
11-30-2018
09:17
14:34
I have just had to return my Charge 3 after only buying it on 3/11/18.
Display stopped working for no apparent reason. Store Tech said he had never seen it happen before. So replaced it. So not impressed.
03-25-2019 09:32
03-25-2019 09:32
I purchased my charge 3 in November and the display quit on me today; tried the solution of a restart and it works; but what bothers me is why is the display malfunctioning in the first place?
03-25-2019 09:43
03-25-2019 09:43
I have no idea why the Fitbit quits display stops working. I only followed he advice of one of the Fitbit advisers to get mine working again.
Best Answer03-25-2019 09:54
03-25-2019 09:54
@BernardJ wrote:I purchased my charge 3 in November and the display quit on me today; tried the solution of a restart and it works; but what bothers me is why is the display malfunctioning in the first place?
I agree @BernardJ ...I need either a charge cord to reset or my smart phone to change the face to regain my display. There should be a solution to make it so it stops happening.
03-27-2019 14:30
03-27-2019 14:30
I tried the suggestion but clock display still not working.
03-27-2019 14:55
03-27-2019 14:55
I don’t know what to tell you. Did you try turning off your phone and trying again? Be persistent and try a couple of times. This shouldn’t be happening with brand new devices. I hope Fitbit is hearing all of these problems. Good luck 🍀
03-27-2019 16:02
03-27-2019 16:02
Mine has went blank twice now & have had it for a few months but this works everytime. Thank you
03-30-2019 17:02
03-30-2019 17:02
Totally worked for me. Thanks.
Best Answer04-15-2019 04:16
04-15-2019 04:16
Tried your suggestion 👍worked fine thank you
Best Answer04-18-2019 14:03
04-18-2019 14:03
04-18-2019 14:25
04-18-2019 14:25
Did you change the clock face? Go to your Fitbit app in your phone. That always works for me.
Best Answer04-18-2019 15:10
04-18-2019 15:10
I didn’t the reset steps, received the smiley and took off the charger only
to receive a blank screen again. Any other suggestions
04-18-2019 16:47
04-18-2019 16:47
Did you try changing the clock face on the phone app? Always works for me.
04-20-2019 20:26
04-20-2019 20:26
Thank you for the instructions to restart my watch. It worked perfectly!
04-21-2019 09:45
04-21-2019 09:45
Best Answer04-21-2019 21:30
04-21-2019 21:30
09:33
08:34
04-22-2019
09:33
08:34
Hello guys, thanks for your participation in the Community.
I am sorry for the delay in respond and I appreciate all the efforts in trying to fix this display issue by yourselves.
@SunsetRunner, @Marels, @letmego212, @BernardJ, @ORANGEinINDY, @reetytru, @SheilaMcGraw, @henry32, @TheodoreBear, @fifib and @Mainer57, it's great to hear that your trackers are now working properly. We are not sure what might have caused this, but we would expect this to be a one glitch and I would ask you to keep an eye on your trackers, and in the case this happens again, let me know and I will be glad to further investigate.
@mamaangle51, @Nana1954, @Run4Ever19, @Yashdot, @Scrunch and @Cykeprof, if your trackers aren't turning on, I recommend taking a look at this post and follow the instructions provided there.
I will see you around. 😊
Best Answer04-22-2019 09:53
04-22-2019 09:53
what if this doesn't work? I tried it a few times. I get a smiley face, unplug, and still a black screen.
Best Answer04-22-2019 10:53 - edited 04-22-2019 10:53
Have you tried changing your clock face in the app (on your phone)? That usually works for me.
These methods are quite a PITA just to get your watch to work right, but they usually work for me. There REALLY needs to be a firmware update to resolve this! These work-arounds are not a resolution.
Best Answer04-22-2019 20:46
04-22-2019 20:46
Best Answer04-22-2019 22:16
04-22-2019 22:16
