06-08-2018
06:21
20:07
06-08-2018
06:21
20:07
I have two fit bit hr charges one is under 12 month old, it’s fault is the light on the screen and display is so light it’s unreadable?
The second fit bit hr charge which is just over 12 months old is stuck on the battery display and I cannot remove it or move it forward, both have been re synced several times but nothing has changed?
What can I do
08-12-2018 07:54
08-12-2018 07:54
Hello @Henny25
This fix has worked for some of us. Here's how to do it in the link below:
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
06-08-2018 09:38
06-08-2018 14:07
06-08-2018 14:07
Welcome to the Forums @Henny25!
Thanks for sharing your inquiry, let me help you out. I totally agree with @JohnnyRow the first step to attempt would be the restart, in regards of the tracker that got stuck I recommend setting it up as a new device and keep an eye on it.
Let me know how it goes!
08-11-2018 15:34
08-11-2018 15:34
Thanks for the advice I had tried it over and over.
But some months on and still the same at a loss as what to do?Stuck on this display!
Best Answer08-12-2018 07:54
08-12-2018 07:54
Hello @Henny25
08-13-2018 02:40 - edited 08-13-2018 02:41
Thankyou so so much, I'm very happy i now have a working fitbit 🙂
05-01-2019 08:30
05-01-2019 08:30
I have the same display problem, have tried a restart but that doesn`t work. I can`t access the link, could you resend please?
Best Answer01-08-2020 05:55
01-08-2020 05:55
Can you repost the link or send it to me. I cannot access the link.
Best Answer05-23-2020 10:12
05-23-2020 10:12
I can not access the link. Pls post the solution for the dim display issue. Thanks.
08-08-2020 12:08
08-08-2020 12:08
Why do I not have permission to view the link that says this fixes it? What are they trying to hide?
Best Answer09-19-2020 00:46
09-19-2020 00:46
The recent iOS 14 update on my iPhone seems to have kicked the Brightness setting on my Charge 23 to Dim. Unfortunately, that makes it really hard to find and set the setting, but if you go into a dark room and maybe use a magnifying glass or at least reading glasses it's there. You can set it back to Normal, if you can see it well enough to do that. That still leaves some of the other settings too dim to read, which seems to be Fitbits user interface for telling you they're turned off or something.
Best Answer11-09-2021 07:28
11-09-2021 07:28
Can you please repost the instructions to make the Charge HR screen brighter.
Thanks
