02-21-2022
14:00
18:10
EdsonFitbit
02-21-2022
14:00
18:10
EdsonFitbit
I am living in the US but planning a trip to Iceland. Do I need a special voltage converter or can I just buy an adapter plug to charge my device while I am there?
02-21-2022
18:07
08:51
02-21-2022
18:07
08:51
Welcome to the Fitbit Community, @tamacat.
Thank you for your question.
You can plug the charging cable that came with your Fitbit Charge 3 into a USB port on your computer, a UL-certified USB wall charger, or another low-energy device. You can find tips to charge your Fitbit device in this article.
Have a nice trip. See you around.
02-21-2022 18:13
02-21-2022 18:13
02-22-2022 13:18
02-22-2022 13:18
Thanks for your response, @tamacat.
To charge your Charge 3 in Iceland as well as in any other country you can use the same USB wall charger you use to charge your cellphone.
Have a nice day.
02-22-2022 14:06
02-22-2022 14:06
02-23-2022 12:34
02-23-2022 12:34
Thanks for your question, @tamacat.
Just the plug adapter that is shown in the image attached above should be fine to charge your Fitbit Tracker. You don't have to worry about the different voltage because the USB wall charger does the conversion. On the label you should be able to see a range of numbers like 100 V to 240 V, this means that it can handle outlets from countries all over the world.
See you around.
