06-20-2017
10:04
20:15
06-20-2017
10:04
20:15
Are Fitbits repairable or do you have to buy a new 1. My 4 month old puppy got ahold of it yesterday and chewed it and now the heart rate monitor does not work. Also the band is damaged and it doesn't look like a new band can be added.
Thanks
06-20-2017 11:22
06-20-2017 11:22
No, it can't be repaired. You have to buy a new one. Maybe a Charge 2, where you can replace the wristband. And don't forget to buy some toys for your dogs.
06-20-2017 11:37
06-20-2017 11:37
That's correct Dog eating is not covered under the warranty
https://www.fitbit.com/legal/returns-and-warranty
Wendy | CA | Moto G6 Android
Best Answer06-20-2017 11:50
06-20-2017 11:50
Best Answer06-20-2017 11:52
06-20-2017 11:52
You should take care of things like that. It can break apart and your dogs eats the pieces. Not very healthy.
Best Answer06-20-2017 12:22
06-20-2017 12:22
06-20-2017 12:22
Best Answer03-23-2019 09:36
03-23-2019 09:36
my cat chewed my fit bit band and now I feel bad because it was a gift. I don't think mine is as bad but if you found a way to fix it please let my know
Best Answer07-11-2020 07:55
07-11-2020 07:55
My 11 week old puppy just chewed up my Fitbit Versa 2 band last night and today I tried using superglue to hold it together until my new band arrives
