07-19-2019
18:24
10:55
07-19-2019
18:24
10:55
I need to edit my run distance, but every time I hit done, it reverts to the original distance. I never had this problem in the iPhone app with my Charge 2. Is this a Charge 3 problem?
Thanks,
Jason
07-20-2019 17:16
07-20-2019 17:16
Same issue, here. iPhone 8, app version 3.1, Charge 3 less than a week old. Fitbit recorded distance was 3.16, mapped distance was 3.42. Attempted to edit, like I have to almost ever run, and it reverts to 3.16 after changing to 3.4. Good job guys. Not really.
07-20-2019 17:32
07-20-2019 17:32
This issue is actually at the server level. So when I looked at the stats for the run mentioned above, I noticed a discrepancy between the pace time calculated in the app versus the web UI. I noticed the pace was significanty lower on the Web UI. Why? Because I was noodling with the edit feature in the app and I had moved it to 3.6 miles. So i went back to the app, set the distance to 3.2 miles, saved the change in the app, then refreshed the Web UI. Well, the pace is now higher as I would expect. Funny thing is, the distance on both the web UI and the iPhone app still shows a distance of 3.16 miles. And, changing the distance only effects the pace measurement displayed on the web UI, not in the iPhone app. You guys have some digging to do. If your looking to hire a QA guy, let me know. I'll find the bugs. BTW: you owe me $50 for the 1/2 hour service call. You're welcome.
07-29-2019 08:30
07-29-2019 08:30
Hi Fitbit,
I still have this issue and have not heard from you. I have tried all of your solutions posted here, but none of them fix the problem and clearly I'm not the only one who has the issue.
Thanks,
Jason
05-12-2020 11:37
05-12-2020 11:37
Going on a year later, same problem with a brand new Charge 3. Getting nowhere with customer service.
