Empty battery won't charge
ANSWERED
My battery is empty, now it will not charge. Any advice? Thanks
66 REPLIES 66
My Fitbit is showing a bar that looks like it’s loading. I have charged it for a few hours and tried resetting it many times while on the charger it showed the battery full I went to the app and it says battery empty and won’t sync. I tried resetting it a few more times still nothing. What do I do?
Hi, my Fitbit Ionic battery is completely empty and I don't see if it is charging. Nothing on screen. Please help me what to do. I have been using Ionic since 2 months and first time my battery is completely empty. I tried to press the left button but nothing heppend
@_Krystal_
Try to forget your device if yours looks like this, forget your device should get you to complete the update.
https://help.fitbit.com/articles/en_US/Help_article/2047
Forget your device video
https://www.imore.com/how-to-fix-bluetooth-iphone-ipad
Syncing
https://help.fitbit.com/articles/en_US/Help_article/1866/?l=en_US&fs=RelatedArticle
 Community Council Member
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
>Contact
Hello @ula.rb
There could be a few things going on here, a bad charger, a bad cord or a bad connection. Check all of those items.
Also, plug the USB into a computer and charge it from there. Give it a couple hours to charge.
Let us know the outcome.
>Contact
The first picture is what my Fitbit charge hr looks like. I have forgot the my Fitbit but it won’t find it and now what it’s doing is once in a while it will show a full battery charge and the half loading screen. When the full battery shows it won’t connect on the app it says full battery it never syncs and when I reset it it goes back to the half loading screen
@_Krystal_
Great, sounds like you can do step 3 now.
See it in the link below
>Contact
I tried that it’s still doing the same thing. I did finally get it to connect back to the app on my cell phone but it went relight back to doing what it was before with the no syncing and the half loading bar.
@_Krystal_
Plug it into your computer and can you do step 4.
>Contact
Hello everyone!
Glad to read that our support team helped you out @Mamarabs!
@ula.rb It could also be that because the battery is empty, it is taking a while to charge again. After leaving it there it should start working.
@_Krystal_ Please do follow the steps provided by @ACG and keep us posted on how it goes.
@ACG Thanks for being around to help our users!
Feel free to reach out with any questions.
Lanuza | Community Moderator
Remember to vote for posts that helped you out! Tired of the same workout music? Try a Podcast! 🙂
I have tried plugging it into my computer the same thing happened also it seemed to have reset itself but still no fix.
@_Krystal_ & @LanuzaFitbit
Great you see it resetting itself.
Maybe go back to step one, keep it plugged in so it stays charging.
>Contact
It went back to the half loading bar. I have had to reset it maybe 30 times just to connect it back to my phone then it went back to the loading screen.
@_Krystal_
Mine looked a bit different in Nov 2017. Have a look at message 2 and the steps I did to make it work again.
Message 2
>Contact
It still isn’t showing up in my Bluetooth or connecting to anything
Does it say anywhere "add a new device", click it if it does.
Also, turn your Bluetooth off and on or turn your phone off and on.
>Contact
I can set up another device but the same thing just happens it’s got the half loading screen and won’t do anything or connect to anything
Ok, maybe try a factory reset and then set up a new device.
>Contact
I did try to factory reset it but because it’s stuck on the half loading screen it won’t reset it. I keep trying to reset it by holding it for the 10 seconds it turns off the back to the loading screen. If I can’t get it to the battery screen I can try to factory reeet it but no luck so far. I’m almost ready to throw it out
@ACG wrote:
@_Krystal_
@_Krystal_
I hear you, you may have to do step 6 in the above link.
>Contact
@_Krystal_
Here are some success stories on getting them running again.
Go over the steps one more time.
https://community.fitbit.com/t5/Charge-HR/Charge-HR-won-t-Sync/m-p/2850443#M204898
>Contact
