04-21-2016 20:49 - last edited on 09-06-2020 20:15 by MatthewFitbit
07-22-2018 09:06
07-22-2018 09:06
Just some more info on how todo resets
Restart your FitBit
http://help.fitbit.com/articles/en_US/Help_article/1186
Restart your Fitbit Charge
https://m.youtube.com/watch?v=JPvdDoWGckM
Factory reset
https://help.fitbit.com/articles/en_US/Help_article/1606
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
07-22-2018 14:31
07-22-2018 14:31
Thank you for your help. Problem has been solved - I have charged battery all night, and pressed 2 buttons left and right at the same time. And now working 🙂 thank you
07-22-2018 14:34
07-22-2018 14:34
07-22-2018 14:35
07-22-2018 14:35
@ula.rb, well done! Your button presses initiated a restart -- that will solve a lot of problems! So glad yu are back up and running again.
07-26-2018 07:38
07-26-2018 07:38
Hi everyone! Good to see you all in the Community Forums! 🙂
I'm glad to hear that most of your trackers are working fine now!
@_Krystal_, are you still having problems with your tracker or is it working fine by now?
07-26-2018 09:25
07-26-2018 09:25
My Fitbit is completely broken. I called Fitbit to see if there was anything else I could do. They said no I would need a new one. Thank you to everyone who tried to help.
07-30-2018 08:36
07-30-2018 08:36
Thanks for getting back @_Krystal_ and I'm sorry about that.
If you need anything else, we're here to help!
08-15-2018 14:38
08-15-2018 14:38
I actually had a bad charger. Not sure if I left it plugged up and it burned out? Luckily had an extra one and tried it and it charged right up.
03-04-2019 08:45
03-04-2019 08:45
I have a CH2 and it holds the full charge only few seconds, even responds, then goes dead and needs recharging. I tried the recommendations but I seem not successful. What am I missing? Help.
03-04-2019 08:51
03-04-2019 08:51
04-26-2019 07:57
04-26-2019 07:57
I am experiencing the same problem with my Charge 2. Charged and it showed full battery but died in a short timing. Tried charging it a couple of times today, restarting and it still didn't work.
07-19-2019 18:04
07-19-2019 18:04
Ok so glad I saw this. Going to try this when I get home
07-25-2019 16:22
07-25-2019 16:22
Hey I followed the forums tried multiple times holding the button down counting to 30 sec it wont turn back on also I have to charge this every day like it only last up to 8 hours then dies this just started happening this week I dont know if its broken or has water damage I dont know 😞 any advice
07-25-2019 17:43
07-25-2019 17:43
Yeah I did all that too. Reset it a few times. Mine would only stay charged an hour. It finally gave up forever. I’m now shopping for a new one but might not do Fitbit again as this will be like my third one
good luck
07-26-2019 19:43
07-26-2019 19:43
07-27-2019 05:54
07-27-2019 05:54
07-27-2019 06:13
07-27-2019 06:13
09-25-2019 03:44
09-25-2019 03:44
I am having the same issue - I have started doing this solution however I've found that the Fitbit is getting extremely hot after only a short amount of time connected. So far there is no activity with the screen and it doesn't vibrate either. I want to leave it on charge just to see if this helps resolve it but I'm worried about why it's getting so hot.
Any advice would be appreciated, thank you!
09-25-2019 04:17
09-25-2019 04:17
Hi, @JK_ , I would say that if your Fitbit is getting very hot while charging, that is not a good situation.
I have flagged this post for moderator attention, amd someone should be in touch with you soon.
09-25-2019 20:44
09-25-2019 20:44
Hello @JK_, welcome to the Community Forums! Thanks for bringing this to my attention @Julia_G, your willingness to help is always appreciated.
@JK_ I was informed by our Customer Support team that they already provided you with assistance regarding the inconvenience you were experiencing with the battery of your device, therefore, my best advice for you since you already contacted them is to contact them back if further assistance is required or if you have any additional questions about the outcome of your case, I'm sure that they'll answer all your doubts.
Please do not hesitate to contact me back if you need anything else, I'll be around.
