08-27-2017
06:34
09:26
08-27-2017
06:34
09:26
I have fully charged the device but now there's only a exclamation mark on the display. The syncing is keeping failing, and the update failed a few times as well. I have tried log out, turned off the Bluetooth, and restarted my phone and the device for several times, but they all failed. Please help!
08-27-2017 11:19
08-27-2017 11:19
Welcome to the forums!
1) Restart your device
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
In your smartphone, with your Bluetooth turned off,
1) Go to your Setting >Application Manager > Fitbit App
2) Clear Cache and Clear Data and Uninstall
3) Reinstall the app, and allow the app to turn on your smartphone's Bluetooth when prompted
In your fitbit app, go to your device, and:
1) Turn ON All-Day Sync
2) Turn OFF Always Connected phone support
Keep us posted!
Look around the forums and join in on some of the discussions! Lot's going on!
Hope to see you around!
Wendy | CA | Moto G6 Android
08-27-2017 11:19
08-27-2017 11:19
Keep us posted!
08-27-2017 11:23
08-27-2017 11:23
The exclamation mark means something has failed, and there usually is something else displaying on the screen. Could you post a photo @Annasaycheese if what @WendyB suggests doesn't work?
08-27-2017 16:03
08-27-2017 16:03
Thank you so much! The problem is solved!(・∀・)
08-27-2017 16:10
08-27-2017 16:10
That's great!
Happy stepping!
Best Answer11-06-2017 07:24
11-06-2017 07:24
This is not working for me!! I unistalled from my Iphone 6 and reinstalled app. However the fit bit continues to have exclamation point and now will not pair with my phone. PLEASE HELP
11-06-2017 09:08
11-06-2017 09:08
Is there anything else on the screen besides the exclamation point!
Best Answer11-06-2017 14:58
11-06-2017 14:58
I hooked it back up to charger and shows halfway charged and exclamation is gone but it stll will not synch to my iPhone or do anything
Best Answer11-06-2017 17:44
11-06-2017 17:44
My Fitbit screen has an exclamation mark on it. It isn’t syncing to my iPhone. I’ve already gone through all your suggestions, what next?
Best Answer11-06-2017 17:45
11-06-2017 17:45
I have already done all these suggestions and they didn’t work!
Best Answer11-06-2017 17:49
11-06-2017 17:49
It shows a picture as the Fitbit is halfway charged and the exclamation mark is in the middle just as it has been for the last several hours I’ve been working on this! I’m VERY frustrated!
Best Answer11-06-2017 20:27
11-06-2017 20:27
Is the bar a standard battery bar or a thinner bar telling you the firmware update has not finished?
Best Answer11-07-2017 05:59
11-07-2017 05:59
It is not the standard charging bar. It is a fixed bar made of thin lines and goes to the middle of the bar. This morning the ! Has gone. Before I plugged it in nothing would show on the bar. It has been plugged in for about an hour with no movement on the bar.
Best Answer11-07-2017 06:03
11-07-2017 06:03
Last night right before I gave up, I was getting a message that said
FBBluetoothErrorDomain error 18
however th Bluetooth was on. When I went to Settings it was showing the Bluetooth wasn’t connected.
Best Answer05-30-2019 05:35
05-30-2019 05:35
I was unable to restart my Fitbit following the steps. When I put in the charger, the Fitbit does not vibrate and only displays the explanation point. I tried holding the button for 4 second and nothing happened. When I unplug from the charger, I get nothing.
03-21-2020 18:29
03-21-2020 18:29
My versa 2 will not charge, there is no green lights and if I push the button on the side I get a battery puc with 1 bar and an explanation. I have uninstalled and reinstalled the app and nothing has changed. My versa did the same thing and this is the replacement doing the it again.
Best Answer07-23-2020 09:09
07-23-2020 09:09
I tried this but still have a white circle with a black exclamation mark. Any ideas? Thanks
Best Answer10-26-2020 09:31
10-26-2020 09:31
Try updating using the Fitbit app on a computer. That fixed it for me. Had to run the update 4 or 5 times but it finally worked
Best Answer12-30-2020 17:57
12-30-2020 17:57
My Charge 3 did this, and none of these remedies worked. It no longer charges even though it is still keeping the time so far. All I get is the big battery with the ! and one bar on the battery no matter how long I charge, or where I plug it in.
