02-24-2017
06:00
10:13
02-24-2017
06:00
10:13
Is there a way to remove some of the real-time stats that display during a run? (Similar to how you can uncheck the activities that show up on "Exercise Shortcuts")
I generally only care about distance and heart rate while running, and there are currently seven stats that I have to scroll through which is annoying while running.
02-24-2017 06:55
02-24-2017 06:55
@stm027, in the Fitbit app Device Settings, select Customize Stats to open that screen. There you can select or deselect stats to display on your tracker, or you can re-order they way they display on the screen. After you make changes to the app, sync your tracker to push the changes down to it.
Best Answer02-24-2017 08:01
02-24-2017 08:01
Larry,
You are referring to changing the normal stats (when you are not in the middle of an exercise).
I am asking about the stats that show up when you are engaged in an activity like a run. Each tap displays a timer and one of seven stats: total distance, current heart rate, current pace, average pace, calories burned during activity, steps during activity, and current time.
I would like to remove all but the total distance and current heart rate.
04-06-2017 20:49
04-06-2017 20:49
@stm027 wrote:Larry,
Same here. I want to be able to see just steps, stopwatch and time. Not cal, hr, km, pace. Is there a way to change disable these other options?
Also, after the activity finishes, I would like to automatically go to the home screen, not have to scroll through the stats etc to get back to it.
04-29-2017 06:24
04-29-2017 06:24
Agreed. I was searching on how to change realtime stats during a run and found your post. I would like to edit stats shown to only pace and HR. I have no interest in the others and it's difficult to tap through screens while running.
07-15-2018 03:15
07-15-2018 03:15
Hi there. Was a resolve ever offered for this? I too am frustrated with having to scroll through all of the realtime stats. It is really awkward to do whilst running. If you know how to select only the stats required, I would be very grateful to find out! Thanks.
01-07-2019 14:51
01-07-2019 14:51
I’m pretty sure you can click on the exercise tab on the watch, click settings and then click customise stats. Then click middle stat and untick whatever it is you do not wish to see.
hope I was helpful!
