08-23-2016
04:37
20:15
08-23-2016
04:37
20:15
Hi,
The competitors have a feature called "Find my phone". It is a very simple thing and very usefull. If you lost your phone there should be an option "Find my phone" on the Fitbit wristbands that will enable a sound to your phone to easily find it.
Please implement it via firmware/software updates an all wristbands and smart watches!
02-03-2019 14:08
02-03-2019 14:08
@deborahdwilkins I work at a solution that could be approved by Fitbit team review, but for now, as workaround you can go in your Android settings, then Sound, then Default Notification Sound and select other sound, eventually a longer one. Anyway, tapping multiple times on the screen remains a very accessible approach, isnt'it?
Best Answer02-03-2019 20:05
02-03-2019 20:05
Will this work for iOS and Fitbit Charge 3?
Best Answer02-03-2019 20:48 - edited 02-03-2019 20:49
@ladybitoun on iOS it will be available soon, possible even starting today because it is already in review at Apple.
Regarding its availability on Charge 3, it is not possible right now due to technical restrictions, at least for developers.
Best Answer02-05-2019 07:59 - edited 02-05-2019 08:01
It's nice to see you here @bogdanims, @deborahdwilkins, @ladybitoun.
Thank you for your comments @bogdanims. As you mentioned on your post this app is now available for Android devices, @ladybitoun it's coming soon for iOS.
@deborahdwilkins, thank you for sharing the issue you're having with this App:
Let me know how it goes.
