08-10-2020
12:15
16:32
08-10-2020
12:15
16:32
My Charge 3 went through a firmware update today (v20001.88.11) and now there isn’t an option to set a silent alarm. During the update it said that they would be deleted and I’d have to reset them but that option isn’t anywhere that I can find it now.
08-25-2020 08:02
08-25-2020 08:02
This is the absolute worse change that could have been made. Who wants to set an alarm on a 1 inch screen when previously you were setting the alarm on the screen on your phone?. Whoever at Fitbit recommended this change, should be fired.
08-25-2020 08:03
08-25-2020 08:03
I've just set multiple alarms, there's a + button when you set the alarm. But I can only set the alarms for tomorrow, unfortunately there's no option to repeat them..
08-25-2020 08:16
08-25-2020 08:16
Best Answer08-25-2020 08:25 - last edited on 08-30-2020 16:07 by LiliyaFitbit
Totally agree. It’s almost as if some yahoo said one day, “Let’s see what we can do to piss the most owners off”!
I know, let’s do away with the silent alarm function on the app and make everyone use a tiny screen. Yep, that should work.
It worked. Jeez!
Moderator edit: format
08-25-2020 08:42
08-25-2020 08:42
I was able to add more than one alarm. After setting up the first alarm, start over and go to Alarms and you'll see a plus (+) sign and you can add another alarm.
Best Answer08-25-2020 08:53
08-25-2020 08:53
I tried setting alarms on my PC app (about 10 times today).... doesn't work!!! I re-synced, and reset my watch, as well. Doesn't work. I have a hard enough time reading my watch, let alone, setting alarms. I was able to set one up from my watch, but, it was cumbersome!!! I had 4 alarms set up before, and will have to try to repeat on watch, with the same settings. What a PITA!! If Fitbit doesn't fix this, I may have to move to some other/brand device.
08-25-2020 08:55
08-25-2020 08:55
Best Answer08-25-2020 09:31 - edited 08-25-2020 09:32
When you set a new alarm in the watch, it has by default activated the "Smart Wake", where it actually wakes you up in a 30 min. window around your set time according to your sleep stages, that is why it woke you up before.
Swipe to your set alarm, click on it and scroll down until you see the "Smart Wake" setting. Click on it once to set it to Off.
Hope that helps 🙂
Best Answer08-25-2020 09:36
08-25-2020 11:37
08-25-2020 11:37
I really relied on my silent alarms. I dont use it it to wake up. I have hourly responsibilities with my job and I consider this function useful. when I get sidetracked. Please reinstate this function. I'm so disappointed with you Fitbit.☹
08-25-2020 13:14
08-25-2020 13:14
You can do it from your PC. I have Windows 10.
Make sure you turn off Bluetooth on your phone.
Next go to Settings Devices.
Unpair your Fitbit (remove)
Pair it again it should find the device.
Go into the Fitbit App on the PC and sync it.
Next Click on your picture go to alarms
Set your alarms then it should sync.
Next remember to turn Bluetooth on in phone. You should be good to go.
Hope this helps. I know it works for me.
Best Answer08-25-2020 13:20
08-25-2020 13:20
Yes, it works but the trick is you need to unpair on the PC then pair it again. This way it will sync using PC app.
Best Answer08-25-2020 13:30
08-25-2020 13:30
Best Answer08-25-2020 18:14
08-25-2020 18:14
Your welcome! It's a pain but it does work.
08-25-2020 18:17
08-25-2020 18:17
Turn it off.. It will then use the time that you setup.
Best Answer08-25-2020 19:58
08-25-2020 19:58
How stupid, an update that removes a very useful function from my iphone app and forces me to do it on my fitbit 3. I would not have updated if I knew this would happen.
Surely, Fitbit being customer focused will reinstate it.
08-28-2020 09:12
08-28-2020 09:12
I hope you are correct about Fitbit responding but so far it is dead silence, which would indicate they are hoping we get tired and go away.
Has anyone noticed that the alarm screen lettering is very dark and hard to see?
Tried adjusting the screen brightness from auto to normal, thinking it would be better, but it does not help. The add alarm plus symbol is bright but the lettering is dim.
As if this update isn't annoying enough.
Why would the lettering on that one screen be so poorly lit?
I'm on my 4th different Fitbit over the years and have always thought highly of the product.
Not anymore.
Can anyone suggest an alternate company with the silent alarm function and an interest in customer complaints?
08-28-2020 18:31
08-28-2020 18:31
They do not plan on revisiting this change anytime soon.
Best Answer08-29-2020 07:38
08-29-2020 07:38
I agree! I can't read the fitbit that well to start with, even with reading glasses and now I can't set my multiple alarms easily anymore on the app. Fitbit needs to have over 40 people test their apps. They forget that Gen Xers use fitbits!
08-29-2020 08:14
08-29-2020 08:14
