08-10-2020
12:15
16:32
08-10-2020
12:15
16:32
My Charge 3 went through a firmware update today (v20001.88.11) and now there isn’t an option to set a silent alarm. During the update it said that they would be deleted and I’d have to reset them but that option isn’t anywhere that I can find it now.
08-21-2020 09:05
08-21-2020 09:05
08-21-2020 09:13
08-21-2020 09:13
I worked as a developer. You never take anything away from a user. Only improve on it.
08-21-2020 09:51
08-21-2020 09:51
I need different alarms during the week ugh!! This is one of those If it’s working leave it alone!!!
08-21-2020 10:03
08-21-2020 10:03
Just an FYI if you have a PC Using Windows 10 the Fitbit app has not changed. I set my alarms using that dashboard. More than one way to skin a Fitbit..... LOL!!
08-21-2020 10:14
08-21-2020 10:14
Where is it at? I don't seem to be able to stumble onto it!
Best Answer08-21-2020 10:50
08-21-2020 10:50
Great Thanks for that. I use an Apple and I have found it there as well in my Charge 3 settings area.
Best Answer08-21-2020 10:54
08-21-2020 10:54
Hi there,
someone has just pointed out to me that if you have a computer try logging into Fitbit and for him and myself, I use a Mac, I am still able to set multiple alarms thru the site....not the app. Hope this helps you!
choose the wheel in top right corner...settings...
then on the right side menu choose charge 3 view device settings
silent alarms for me is the top most choice. You can set alarms like we could on the app. Change by clicking on the pencil.
hope this helps
Best Answer08-21-2020 11:00
08-21-2020 11:00
Best Answer08-21-2020 11:05
08-21-2020 11:05
On your Fitbit device swipe right until you find alarms then tap on it. Set the time then tap on repeats.
08-21-2020
11:11
10:14
DavideFitbit
08-21-2020
11:11
10:14
DavideFitbit
Yes, Window 10 Fitbit dashboard has not changed. So, I checked the alarms :alarm_clock: and it's fine. Word to the wise do not update your computer app.
do not install any updates on your PC for Fitbit.
Best Answer08-21-2020 12:37
08-21-2020 12:37
Hi,
Thank you for mentioning about the Win10 app, I'd not thought about it as I've never used it before. I'm having problems getting it to work though unfortunately. It looks like it is saving the alarms in the app but they're not being activated on my Charge 3 and are also not shown under the alarms setting on the Charge 3. Have you got any ideas please? I've tried forcing a sync.
Thank you
08-21-2020 12:37
08-21-2020 12:37
My fitbit has been problems since I own it. Steps is the only exercise that really works. Removing silent alarms from the app is the last straw. I think I'll try a Samsung.
08-21-2020 12:42
08-21-2020 12:42
Make sure your Bluetooth is on in your PC. Then you will be able to sync it from the PC app.
Go to settings in Windows then devices.
Best Answer08-21-2020 13:14
08-21-2020 13:14
Hi,
Thanks for replying so quickly to help. The Charge 3 is paired via Bluetooth. My step count is the same on the Charge 3 and in the Win 10 app. It is just the alarms that won't sync. 😞 I'd be really grateful of you could check that your alarms are syncing on your Charge 3 please.
So unhappy about the update that Fitbit have rolled out. No warning was given of the full content and implications of the update. I have disabled automatic updates to all Microsoft Store apps. Very frustrated that I have to use a sledgehammer to crack a nut due to Fitbits actions. I only want to disable it for Fitbit.
Regards,
'Unhappy customer who won't be recommending or buying more Fitbit products until this is swiftly resolved'
08-21-2020 13:16
08-21-2020 13:16
Totally agree.....fire that idiot and put it back....i rely on that not to wake partner....ffs idiots
08-21-2020 13:18
08-21-2020 13:18
good for you.....now can you send everyone a step by step guide
08-21-2020 14:00
08-21-2020 14:00
Your Charge3 is connected to your phone. In order to connect it to the Windows app, you need to disable the Bluetooth on you phone first. Then you will be able to connect it to the Windows app by clicking on the sync icon. The steps and other current information you see in the Windows app comes from the Fitbit server to which your phone, currently connected to your Charge3, has sent it.
Best Answer08-21-2020 14:17
08-21-2020 14:17
Thank you for trying to help. I have disabled Bluetooth completely on my phone (not a great customer experience!) Walked around (to change my step count). Step count on Win10 app and watch match but still no new alarms shown in alarms section on the Charge 3. Only the one that I have painfully manually set for tomorrow. 😞 From what I have been experiencing, I think the Win10 and Fitbit.com silent alarms have been disabled as well. Very unhappy.
Best Answer08-21-2020 14:41
08-21-2020 14:41
The new alarm is horrible. I have it set for 4:30am and it goes off at 4:06am. There is a "range" - what is up with it? It worked perfectly before this "upgrade"!
08-21-2020 15:10
08-21-2020 15:10
Yes, mine are syncing. Did you reboot your Fitbit device. I know that I rebooted mine. I would give that a try.
