10-21-2016 21:08 - last edited on 09-09-2020 10:26 by MatthewFitbit
10-21-2016 21:13
10-21-2016 21:13
10-22-2016 08:11
10-22-2016 08:11
10-22-2016 08:58
10-22-2016 08:58
@ARose0710 so you don't panic, since we don't know if your tracker has been setup, if the tracker display still shows www.fitbit.com/setup then there will not be any battery charging icon. 30 minutes to an hour will be entry of time to do the setup process.
02-28-2017 13:33
02-28-2017 13:33
Help please. When I pressed the side button the screen lit immediately with www.fitbit etc/setup. However I am uncertain whether there is a charge. It went out almost immediately. During setup on my iPAD it kept searching. Now, I'm charging but how will I know if charging as nothing is on the screen. Thank you.
02-28-2017 13:38
02-28-2017 13:38
@YiveeHP please see my post immediately above yours, i explain aboit the vibration that tells you that it is charging.
03-09-2017 18:17
03-09-2017 18:17
How long does it take to charge the Fitbit charge 2 for the first time.?
03-09-2017 19:45
03-09-2017 19:45
This would depend on what your charging through?
Then again, unless the app tells you that you need to charge it, you might not have to.
06-28-2017 15:30
06-28-2017 15:30
Why is my computer asking me to plug in a toggle when this Fitbit did not come with one?
07-02-2017 09:41
07-02-2017 09:41
Hello @Carmeneva, may i ask what computer you have, and does it have bluetooth 4.0 or better?
Im not sure what this has to do with charging your tracker.
07-02-2017 18:06
07-02-2017 18:06
07-10-2017 17:14
07-10-2017 17:14
Just got my fit bit.
How long dies it take to charge?
I've taped the screen, with no results
PLEASE help!!.
08-24-2017 03:21
08-24-2017 03:21
I face the same problem when i unboxed the device.
Fitbit failed to provide a step by step guide to first time users.
It didn't tell users what should be done first...... to charge the device or to setup with the mobile or other preferred device?
No information, how long the battery should or will be charged for the 1st time?
Looks like the setup guide/manual was done by a bunch of amateurs.
08-29-2017 20:28
08-29-2017 20:28
What's the charging time for new setup
09-01-2017 19:27
09-01-2017 19:27
The charging time will depend on how low the battery is, and what device your using to charge the tracker.
A computer or laptop usb will usually be the slowest, a wall wort usually goes faster.
Now until the tracker is setup there will not be a battery indicator.
On the app it steps you through the setup.
Tapping on help in the spp, or below takes you to Fitbits Help site, where typing in setup will get more info.
Also found on the help site is the user manua
09-03-2017 05:18
09-03-2017 05:18
testing
mum
09-13-2017 03:35 - edited 09-13-2017 03:36
Tried the initial charge of the Fitbit Charge 2 on a laptop - not synced with my account, used solely as a charging source, and after 5 hours, it only charged to 50%. I'm reading that it might take a little longer when using laptop as the source, but thinking there might be something else going on?
09-19-2017 23:02
09-19-2017 23:02
A laptop will take longer to charge then a direct plug in to an outlet. Factors that can make a laptop go significantly slower include the version of the USB port (older versions on older laptops are much slower), power settings on your laptop and whether or not your laptop is plugged in (much slower if its not). Hope that helps you Matador_Mom.
10-08-2017 21:09
10-08-2017 21:09
my fitbit charge 2 will not turn on
10-08-2017 21:27
10-08-2017 21:27
@Tiger12- it doesn't turn on at all? No lights on the back, or anything at all on the face? No setup message?
Did tye unit vibrate while placing it into its powered up charger? Try using the phones charger.
