01-11-2022
09:08
15:58
01-11-2022
09:08
15:58
On a walk today my FitBit when set to Excercise Walk showed 7 miles at the end of the walk. My Garmin Etrex20 showed 6.04 miles. So I exported the TCX file from the FitBit and the GPX file from the Garmin. Here are the results: FitBit displayed 7.0 miles; TCX file gives 6.3 miles; Garmin display 6.04 miles Garmin GPX gives 6.10 miles. So it looks like the distance was around 6.1 to 6.3 miles. Strange the FitBit displayed 7 miles on its face at the end of the walk. This is not a problem Just thought FitBit users might be interested. Another walker uses a Garmin Etrex30 and we often have a small difference between our devices. The frequency of sampling must be a key for the more your sample particularly when walking in a curve will make a difference. Happy excercising and FitBiting.
01-13-2022
12:29
10:21
01-13-2022
12:29
10:21
@grahamm7 , Nice to see you around. Thank you for your message and efforts.
How did you record your walk? Did you start it on the Charge 4 or let it autorecognize it?
Hace you set up you stride length?
I suggest you to have a look at these: How does my Fitbit device calculate distance traveled?
Can I change my stride length in my Fitbit account?
Hope it helps.
01-15-2022 08:16
01-15-2022 08:16
When I use my FitBit to measure a walk. I set it to Excercise Walk and start and wait for the GPS to sync. That is what I did on this occiasion.
The display as I pointed out said 7 miles as far as I remember. However if you look at the Garmin GPS and the track as measured by the FitBit (via TCX) and the Garmin via GPS the figures are: 6.3; 6.04 & 6.1 miles. The FitBit track is still a bit higher but the greater the sampling rate the more accurate the track length. (Think about going round a curve with few samples). I have not idea what sampling rate the FitBit charge 4 uses when tracking walking.
01-16-2022
16:22
10:20
01-16-2022
16:22
10:20
@grahamm7 , Thank you for your reply and feedback.
Please try tracking your walk without a GPS. This can help us determine what is causing the situation.
Have you tried to setup your own stride length as recommended previously?
See you around.
01-16-2022 20:56
01-16-2022 20:56
Hello @grahamm7
Here it the procedure I adopt for my Charge 4
