01-22-2016
08:24
20:15
01-22-2016
08:24
20:15
Hi All –
I am looking for some advice on why my FitBit Charge HR won't turn on. I woke up this morning with it being completely off. I assumed the battery must have been low, so I plugged it into the charger and walked away. It has now been 4 hours and when I pressed the button, I realized not even the battery image was appearing on the screen, the green lights weren't flashing and it hadn't synced since the previous night.
I have a warranty on it, but I was hoping it would be something I could resolve on my own. Any advice? I've had this since Christmas... so not even a month.
Thanks.
01-22-2016 08:27
01-22-2016 08:27
@jessica-l Well that it is not a fun surprise. I suggest trying a restart.
If you get no response from that, you will need to contact customer service. Good luck. Let us know if the restart works!
01-22-2016 08:27
01-22-2016 08:27
01-22-2016 08:30
01-22-2016 08:30
It took 20 seconds, but nonetheless the version number appeared and know it is fully charged. Thank you so much.
01-22-2016 08:41
01-22-2016 08:41
Awesome! Glad it is working for you again!
Was my post helpful? Give it a thumbs up to show your appreciation! Of course, if this was the answer you were looking for, don't forget to make it an Accepted Solution...
01-22-2016 08:49
01-22-2016 08:49
03-29-2016 12:05
03-29-2016 12:05
I have tried this for both 10-12 seconds, and 20 seconds, still nothing, no response.
After about 8 seconds of holding I get one flash of green, then nothing.
HELP 😞
04-20-2016 12:20
04-20-2016 12:20
I held the button down for over a minute before it came back to like (but it did)
05-10-2016 08:00
05-10-2016 08:00
Plugging into a good USB port and holding the 'reset button' on the side for 30 seconds worked for me... on two watches. Good luck!
05-28-2016 01:00
05-28-2016 01:00
I held my button for 18 minutes with no response. Then I hit it with a hammer just like the instructions said and still nothing. any other suggestions
06-16-2016 17:10
06-16-2016 17:10
Thank you so much! This worked for me. I was trying to find a solution because my FitBit wasn't charging so I thought I wasn't able to restart it. I tried it anyways and it worked. I'm not sure how many seconds it took though because I wasn't counting.
07-10-2016 18:51
07-10-2016 18:51
07-10-2016 19:34
07-10-2016 19:34
That worked for me, too. Thanks for your help.
Seems a little user unfriendly....
11-06-2016 14:36
11-06-2016 14:36
12-26-2016 12:46
12-26-2016 12:46
Was hving trouble with ChargerHR not turning on and after holding button for 15-0 seconds it started working again. Thanks for the help
08-25-2020 10:30
08-25-2020 10:30
Hello,
I seem to have the same issue as you
Did you manage to resolve it at all?
Thanks
08-25-2020 11:33
08-25-2020 11:33
09-04-2020 07:26
09-04-2020 07:26
I was just about to give up (my ChargeHR is old and had been sitting with a dead battery for over a year .. or longer?!). I just held it, for over a minute, until I got a flash of green and kept holding until it flashed the version number on the screen. Thanks!
09-04-2020 07:43
09-04-2020 07:43
Hello Andrea,
Thank you for your reply 🙂
So ... you did this ...?
10-24-2020 14:37
10-24-2020 14:37
I got the version number and fitbit icon for a second and it turns off again. Do I need to do something else?
12-07-2020 19:28
12-07-2020 19:28
Did u ever figure it out?
