09-21-2019
04:23
13:05
AndreaFitbit
09-21-2019
04:23
13:05
AndreaFitbit
Hi when I bought my Fitbit it came with a. Charger that has three prongs. I’ve lost that and needed a new one but every charger I buy for the charge 3 has two prongs and won’t charge it?
Moderator edit: format.
09-21-2019 05:10
09-21-2019 05:10
Hi @Abwright - In my experience, because of how they sit, the two prongs make contact with all three, allowing the device to charge. When charging, please make sure that the Charge 3 is set securely in the charger. The connection is secure when the tracker vibrates and a battery icon appears on the screen.
09-21-2019 05:10
09-21-2019 05:10
09-06-2020 01:57
09-06-2020 01:57
I have the same problem. I ordered a new charger from amazon for inspire but it doesn’t fit nor connect. Is there such a thing as a 3 charger? I’m lost
Best Answer11-14-2021 14:28
11-14-2021 14:28
I have the same problem. Can not find a replacement charging cable with three probes.
Best Answer12-26-2021 10:37
12-26-2021 10:37
This doesn't work. I'm just going to get another fitness tracker but get a less expensive brand. What's the point spending so much on something you won't be able to use a year later?
Best Answer02-06-2023 06:03
02-06-2023 06:03
I agree. I cannot find a 3 prong and the 2 prong doesn’t work. This is ridiculous
Best Answer07-23-2023 05:39
07-23-2023 05:39
apparently youve never had one you cant make it slip over two spots they are individual squared off areas mo way to put one prong in two spots...also am looking for a 3 prong charger.
