11-30-2016
23:02
10:26
11-30-2016
23:02
10:26
Hello - I have tried the troubleshooting suggestions for the above problem with no success.
Bought this Fitbit last Friday.
When first set up Fitbit - the notifications worked but this stopped after about three days. In the APP I get prompted to pair the fitbit when I click on 'notifications' and after quite a while of the thinking donut thingy, I get a message 'Bluetooth Pairing Failed'. Bluetooth settings on iPhone shows that the Fitbit IS being picked up and all other syncing IS working. Also not connecting is All Day Syncing...any suggestions?
Things I have tried;
12-01-2016 06:36 - edited 12-01-2016 06:36
@DorindaH Welcome to our Community! Besides the phone restart suggested by@Rich_Laue I suggest you remove your tracker from your bluetooth settings. After this retry setting up the notifications. Also have you tried using this feature with another mobile device? Finally you could remove the tracker from your account (tap the tracker's icon and then the trashcan icon) and set it up again (go to account and then set a new device).
Let me know how it goes!
12-01-2016 05:17
12-01-2016 05:17
Have you tried a restart of the phone yet?
As for the BT pairing message, ive seen screen shots that have a prompt to follow, is this what your using?
12-01-2016 10:35
12-01-2016 10:35
Thank you - Yes have restarted the phone - problem still exists.
12-01-2016 10:43
12-01-2016 10:43
Okay, I have;
12-04-2016 06:47
12-04-2016 06:47
@DorindaH Happy to hear that your Charge 2 is now receiving notifications. I would like to invite you to check our Discussions board where you will find great tips and recipes shared by other members.
Hope to see you around!
Best Answer12-05-2016 09:03
12-05-2016 09:03
I am having the same problem. I have had the Charge 2 for about 3 weeks. Sometimes it will send me text notifications but never phone ones. Yesterday, I wasn't getting either so I restarted the phone and did everything mentioned above - then I started getting the text notifications but still not the phone. Today, same thing, no text - I've done the same things as yesterday and am now getting text but not calls. Is there anything I can do so I don't have to reset everything every day and any suggestions on calls? Thanks.
Best Answer12-21-2016 09:17
12-21-2016 09:17
My notifications all worked fine. Reminders to walk, text messages, calls, etc and I turned them off ( they woke me up one saturday morning when I was trying to sleep) and when I turned them back on they never worked again.
I have now done everything suggested on this page and nothing works. No notifications what so ever.
Any other suggestions
Best Answer12-27-2016 10:46
12-27-2016 10:46
Hello @mjersey when you turned notifications off, did you turn them off in the app or the tracker?
Are they now on in both places?
Can you confirm that Fitbit notification services are running?
Are you able to send a text notification?
What always works for me is a restart of my phone.
Best Answer01-01-2017 20:16
01-01-2017 20:16
Finally. This is the answer people... after many days this finally did it
Best Answer01-03-2017 11:02
01-03-2017 11:02
Have run out of solutions to try which have been suggested. Thought i had succeded, but when I got up this morning my Charge 2 and iPhone 6 had gotten a divorce. I have not been able to get them paired again. Will go back to an old tracker until I can get my tracker checked or have it replaced. Never had this problem with the older, cheaper models of the fitbit trackers. I love the look of the Charge 2.
01-25-2017 05:56
01-25-2017 05:56
had similar issues - tried all recommendations
Finaly made it work again by using the 'forget device' in the bluetooth settings on my iPhone for the charge 2 - then forcing fitbit app to close - reopen and follow the replace device instructions. I have the feeling that the pairing didn't work from within the app when the charge 2 was already connected via the bluetooth on the iPhone (hope this is making sense)
Best Answer01-25-2017 06:54
01-25-2017 06:54
Best Answer03-05-2017 10:36
03-05-2017 10:36
My problem is the similar, my iPhone and fitbit charge 2 were working, but now all of a sudden I am not getting my text or phone calls showing up, what do you suggest?
Best Answer03-05-2017 10:39
03-05-2017 10:39
@Cutiemema, have you checked the Charge 2 itself to verify that Notifications did not get disabled? Press & hold the side button for about 3 seconds to toggle Notifications from Off to On.
Best Answer03-05-2017 11:52
03-05-2017 11:52
Thank you this has just solved my problem too!
Best Answer03-05-2017 13:11
03-05-2017 13:11
That worked THANK YOU much appreciated
Best Answer03-12-2017 00:52
03-12-2017 00:52
Do a Fitbit restart, open the app and go to notifications. You will be taken through the Bluetooth pairing process again and all should be well
Best Answer03-12-2017 03:18
03-12-2017 03:18
Best Answer04-02-2017 07:22
04-02-2017 07:22
I am John ,
my charge 2 is not syncing it , It is not connected by blue tooth , how can I connect it back without losing today's data
