03-14-2018
10:18
18:54
03-14-2018
10:18
18:54
Hi! My Fitbit Charge 2 keeps coming loose from the strap.
I've tried tightening and loosening the screws, and I've also tried a new strap.
No matter what I do the fitbit will not stay secured to the wrist strap.
I can no longer wear my fitbit because it will not stay secured on a strap! Please help!!
I bought it in July 2017.
03-14-2018 10:22
03-14-2018 10:22
I have this same problem. I have been lucky the 8-9 times it has now happened in the last 2 weeks. But one of these times its going to fall off and be lost!
03-15-2018 04:49
03-15-2018 04:49
@Cara_K @lgleiser Welcome! It's great to see you around. You can try pulling the metal tab to the outside so it better secures the tracker. @Cara_K is the new wristband from Fitbit or from a third party vendor?
Let me know how it goes!
03-15-2018 06:47
03-15-2018 06:47
Hi
My Fitbit Charge 2 is fine with the original strap but when I bought a different strap from a third party vendor it just wouldn't stay secure so I sent the strap back. I've worn mine constantly for over a year and it works well.
03-15-2018 09:00
03-15-2018 09:00
Hi! I've tried adjusting the tab and it still won't "catch" onto the fitbit.
The replacement band I got was branded from Fitbit - but I bought it in a local store.
04-02-2018 08:37
04-02-2018 08:37
@AndyLAS @Cara_K sorry for the delay in my response.
@AndyLAS happy to hear that you were able to return the third party wristband.
@Cara_K since your wristband is still giving you issues the best thing to do is explaining this to Support so they can assist you. You will get an email from them.
Best Answer10-13-2019 13:16
10-13-2019 13:16
I am having the same issue have only had my charge 2 for 8 months. What was the solution for you Cara_K?
Best Answer02-01-2020 20:30
02-01-2020 20:30
I have only had mine for a month and the original strap keeps popping off. I’m afraid I’m going to lose it. I found this forum looking for others experiencing the same thing. I love this upgrade fro lm the Alta but am afraid it is also going to fall off and get lost.
06:33
07:16
02-05-2020
06:33
07:16
@Cdane777 It's great to see that you've visited the Fitbit Community! Sorry for the delay in my reply.
Let me help you with your Charge 2 band popping off. I have created a ticket so our Support team can further assist you via email.
Let me know how it goes.
Best Answer02-05-2020 22:40
02-05-2020 22:40
Hi, I have same problems with the straps too. Watch is still very much good condition. Easily came off from my wrist. Luckily, every time it games off, I realize it.
why is it?
Best Answer02-06-2020 15:34
02-06-2020 15:34
I’m having the same problem. My strap keeps popping off. I’ve had this strap for about a year now. Can you help at all?
Best Answer02-07-2020 09:57
02-07-2020 09:57
I have had so many issues with this. The first strap broke at the connection and that was within a year of purchase, so luckily Fitbit replaced it. That has lasted about 7 months and the connection has broken again! They will not replace it. The actual monitor is good, but the strap connectors are crap. You can't wear it without a strap, so I'm guessing if I want to keep using it I'll have to keep buying replacement straps. The concept of changeable straps seems good, but the plastic material is useless. Metal clipping onto plastic just doesn't work, and I don't do any extreme sports that would cause it to break! Obviously, their building in obsolescence.
Best Answer02-07-2020 14:08
02-07-2020 14:08
Hi, I bought my Fitbit inspire HR in May 2019. I bought a second band from Fitbit online in November 2019 but the strap keeps popping out. It seems that there is a space between the watch and the strap, therefor the strap does not click in. The strap comes off multiple times a day.
Best Answer02-11-2020 12:22
02-11-2020 12:22
I have the same problem and am about to throw this Fitbit out the window.
Best Answer02-25-2020 12:57
02-25-2020 12:57
Same problem here. Very surprised that Fitbit would allow this to snowball on social media without some response. Obviously won't be buying another one of these, and wouldn't recommend a Fitbit to anyone.
Best Answer02-25-2020 17:18
02-25-2020 17:18
Best Answer02-26-2020 13:51
02-26-2020 13:51
Moira:
Thanks for the Amazon lead. I just ordered my replacement. Hope it works better than what I have now!
Best Answer04-06-2020 14:37
04-06-2020 14:37
I have same issue. Just chatted with a support agent, but he told me that since my fitbit is 1 year and 2 months, thus 2 months after warranty, I have to buy a new armband.
Very disappointed. I will take the opportunity and change to MiBand Xiaomi.
Best Answer05-12-2020 20:07
05-12-2020 20:07
my fit is just a few months old and ots original strap has started to come off while putting it on.
Best Answer05-13-2020 03:22
05-13-2020 03:22
