Fitbit Charge 2 discharges within 1 days.
Hello,
 after last update my device went from working 2 weeks in beatween charges, to not lasting 2 days.
Anyone else experiencing same problems?
3 REPLIES 3
@Deril A warm welcome to our Community!
Let me help you with your Charge 2 battery not lasting 2 days. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
Let me know how it goes.
Alvaro | Community Moderator
Mine went from a solid five days to not even two as well. I can only say I've noticed this with the recent firmware update.
Hi,
 Thanks for answer, but... I don't have problems charging it. It charges fine within 2 hours.
(And I actualy used difernet sources to charge it..)
The prolem it loses 100 % power within 15 Hours. (Making it unusable...)
